Locking/Unlocking from trunk buttons.
Discussion in 'Gen 3 Prius Technical Discussion' started by mishao, Jul 15, 2010.
  1. mishao
    mishao New Member
    Oceanside
    I was looking at the manual and some things I couldn't do with my 2010 Prius III. I noticed that there was only one button (the long one) as opposed to the two seen in the manual above the back license plate (trunk door). I wanted to be able to unlock all five doors by pressing that button, but it doesn't seem to work.
    Then, I proceeded to try setting the keyless unlocking so that when I put my hand on the passenger door, it would unlock all doors, which does not work either. Did I miss read this or is it not available to all packages?
    Thanks, I couldn't find an answer by searching. So anything would be helpful.
  2. tumbleweed
    tumbleweed Senior Member
    4,067
    690
    Eastern Oregon
    Unfortunately the Prius III only has SKS on the driver's door.
    Prius I no smart key system
    Prius II and III smart key system on driver's door only
    Prius IV and V smart key system on 3 doors
  3. Tideland Prius
    16,406
    ^ What Tumbleweed said. 3-dr SKS is only available on IV and V models.
  4. johalareewi
    johalareewi Member
    393
    44
    uk
    Although he should be able to have all doors unlock when the driver's door is unlocked via SKS. My base model T3 does it. Or maybe this is different for you guys?
  5. Tideland Prius
    16,406
    Yep, that's doable on our models too.
  6. mishao
    mishao New Member
    Oceanside
    Thanks guys, for some reason I thought the manual was specifically for my package Prius only, but it's a general one for all Prius'. :)
  7. Tideland Prius
    16,406
    and for both countries (Canada and US)
