Looking for an independent mechanic, King County, Washington
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by artistic_gore, Feb 25, 2022.
  1. artistic_gore
    artistic_gore New Member
    24
    Washington State
    I would like to get my brakes bled, I had a mishap today changing lug studs and pressed the brake pedal with my caliper removed. I bled the old fashioned way but I can hear my pump cycling and I want to get them bled professionally. I don't want to go to the dealer so I am looking for local options, I know there is Greg's Japanese auto but I'm wondering if there are any other shops that you have had a good experience with. Thank you in advance. And if this is the wrong place for this, please let me know where I should have posted this. Thanks.
  2. tankyuong
    tankyuong Senior Member
    1,555
    661
    Central MO
    You need techstream to bleed properly
  3. artistic_gore
    24
    Washington State
    I know, that's why I want a mechanic to do it. I have a cheap Amazon cable for Techstream but I don't know that it will work for bleeding brakes.
  4. tankyuong
    1,555
    661
    Central MO
    Amazon cable will work
  5. Mendel Leisk
    40,238
    Due to price concerns, or? Doesn't hurt to phone them, get a quote.
    Addendum: @PriusCamper is an independent mechanic in the Pacific Northwest.
    #5 Mendel Leisk, Feb 27, 2022
  6. artistic_gore
    24
    Washington State
    Thank you for the reply Mendel. My local dealership already tried to fleece me once on this car when I went it to get a diagnostic on my traction battery, inverter, a coolant leak and traction control light. The only positive thing I have to say is that the tech actually fixed the traction control issue, it was an issue with the wiring for the right front wheel speed sensor but when I was called they didn't mention that it had been repaired and tried to get me to authorize 3 additional hours labor for further troubleshooting of the system. They also never checked for the coolant leak, I don't think it's head gasket related because I don't have any of the symptoms I have been reading about though I have not done a block test yet.
  7. Rapid
    Rapid Junior Member
    Cumming, GA
    See Dan, who owns Community Automotive (206-246-7500) in Burien, WA.(14803 Ambaum Blvd SW, Burien, WA 98166) He is independent ASE Master and maintains fleets of Prius' used as taxi and ride share around SeaTac. Burien Toyota is just a couple minutes away, and they have parts and can do any factory related work. Six excellent years of Dan working on a variety of cars, but especially my 2010 Prius.
