Looking to change gas motor activation point
Discussion in 'Gen 2 Prius Technical Discussion' started by micaangelo, Apr 18, 2007.
  1. micaangelo
    micaangelo New Member
    Washington State
    I just got into a 2007 Package 5 and think its the coolest car I have ever owned. Since it is under warranty, I dont want to snip or clip anything.
    What I am looking for is a way to change the Gas Engine activation points. For example, I would like the gas motor to wait till I have two battery bars left before it activates to recharge. I would even like to change the activation mph to a higher level. Has anyone tried to get into the Daignostic & Settings menu in a 2007?
    So far the 2006 ways do NOT work... Ugh...
    <_<
  2. donee
    donee New Member
    2,956
    197
    Chicagoland
    Hi Mica...,
    The Prius has a battery management routine which tries to keep it at mid-scale on the State of Charge (SOC) meter. It can get down to two bars, for example, when the car in stop and go traffic, running the AC. But in most traffic it tries to keep the battery at mid charge. Your probably should not fight the car to run the battery down. The purpose of this is to make for a long battery life. Consequently its not adjustable. You will notice that is the weather gets warmer, the car will let the battery go to lower SOC.
    If your goal is to get the best mileage, keeping the battery up above mid charge is advantageous. When the battery is above half SOC, one can generally drop the car into glide (no-arrows) below 40 mpg or stealth (electric drive ) from 40 to 45 at will. With the SOC below half, the car will bring the engine on with the slightest demand for accelleration.
    There is an EV switch sold. With the EV switch, one can drive the car around below 34 mph in full electric mode, with allot more accelleration. I do not have one of those, so I do not know how low it lets the battery go.
    The hybrid concept is not so much to have an EV car, deplete the battery and then charge it back up with the engine pushing the car and charging at the same time, as it is for the battery to supplant the smaller engine during acceleration, and the smaller engine charge and cruise the car inbetween. That way the the engine load is leveled into its most efficient range. Not too much during accelleration, and not too low during cruise. Its this very low power level during cruise that is the real bugaboo for the common gasoline engine. Efficiency at partial power is very poor at these low levels. As bad as one half the best efficiency in a Otto cycle car, or 10 to 15 %. This is the reason most cars get around 20 mpg in city driving. The Atkinson cycle engine in the Prius is at 25 % efficiency at 12 HP output power (highway cruise horsepower most likely) as tested by Argonne National Lab. Which is very good. All the energy comes from burning gasoline in the engine, so the more efficiently that happens, the better the mileage.
  3. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    Doing that will lower performance and mileage, and increase wear and tear on the battery and some drive components. Toyota has already spent a decade optimizing the control system for the Prius, so it is improbable that it can be improved with tinkering. What you might want to do is add the EV button, which will allow more control over the electric mode. The EV button is standard on Prius outside the U.S., so it is a relatively easy installation. Searching PC will give you a lot of information on EV.
    Tom
  4. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    I agree that the closest viable option to try to achieve what you suggest is the EV button. But using it in any manner close to what you describe will lead to lowered FE.
    Try to think of it this way...all of the energy in the battery came from gas...even the regenerative braking is simply recapturing a fraction of the energy expended in gas to get up to speed.
    While electric only can be the most effective means of propelling the vehicle in some situations acceleration from a stop and at higher speeds is not one of them.
  5. viking31
    viking31 Member
    515
    22
    West Central Florida
    <div class='quotetop'>QUOTE(MicaAngelo @ Apr 18 2007, 10:43 PM) [snapback]425762[/snapback]</div>
    One item that many hybrid buyers/owners (and to those who are interested in the Prius operation) seem not realize is ALL the power to vehicle comes solely from the ICE (Internal Combustion Engine). Generally with the Prius (though not always) it is more efficient to have the ICE supply power directly to the wheels and not have to waste power through the generating and storage operations associated with the electric motor.
    While it is good to think "outside the box" (look what Felix Kramer and his associates have done to promote the Prius PHEV (Plug in Hybrid Electric Vehicles)), one can ascertain that Toyota and their engineers have spent hundreds of thousands, if not millions of dollars, in developing and researching the algorithms necessary to ensure maximum fuel economy and also balance the reliability of its associated components with regards to a stock Prius.
    What you are trying to achieve is how a typical PHEV would operate. But with a PHEV you would have much larger capacity batteries designed to deep cycle on a continual basis and you would also have to ensure the electric motors and the transmission would be cooled properly when in the EV mode.
    Rick
    #4 2006
  6. PATAUD
    PATAUD New Member
    The EV mode exist in France, directly "made in Toyota". I think it is nothing more than a gadget, just able to run the car for 2 km max. (1,18 mile) in the best conditions. My 2006 Prius never did more than 1 km in this mode, until the engine goes on ... It is only convenient to pull the car out an underground parking without gas pollution ... if the main battery is fully charged. My idea is that it is not very interessant to spend time and money for that.
    For the Priuschat members who can read French, visit our forum in France : priustouringclub.com :rolleyes:
    Best regards.
    François
  7. daniel
    14,487
    1,519
    Spokane, WA
    Donee's explanation is correct. Changing the Prius's operating parameters would reduce your fuel efficiency and at the same time, put excessive wear on your battery.
    Toyota knew what it was doing. Trust it.
    The EV switch can help in very limited circumstances. NOT to force the ICE to cut out sooner or to stay off longer, but in the kinds of rare situations that the car cannot anticipate. And it is a fun gadget.
    There is really no way to do what you are asking, short of re-programming the car's computer. Think you can do that better than Toyota can? I don't. Welcome to Prius Chat and enjoy your car.
  8. patrickindallas
    patrickindallas Shire rat
    676
    36
    Vancouver, WA
    All of the above + you would probably be altering
    the emission profile too.
    And that's why I bought the car. Everything else is just gravy.
  9. bwilson4web
    15,934
    <div class='quotetop'>QUOTE(MicaAngelo @ Apr 18 2007, 09:43 PM) [snapback]425762[/snapback]</div>
    You might consider mastering the "Gas Engine activation points" and changing your driving style and route to maximize performance. We call it 'route planning' and it works very nicely.
  10. ken1784
    ken1784 SuperMID designer
    2,943
    1,380
    67
    Yokohama, JAPAN
  11. micaangelo
    Washington State
    Thanks everyone for your input! :D
    After several days of practice I think I have finally begun to retrain my foot to the pulse and glide techniques that I have been reading about. I am happy to report that I achieved an average of 64.2 Mpg for city & highway traffic. B)
    Later, Michael...
  12. tochatihu
    tochatihu Senior Member
    9,457
    3,656
    Kunming Yunnan China
    2001 Prius
    Michael, you ought to present your new efforts at
    www.cleanmpg.com
    where they will be especially appreciated, and additional hints abound.
  13. Sho-Bud
    Sho-Bud Member
    190
    Amsterdam, Netherlands
    The only thing I use my EV button for, is on cold days, when the engine is not yet warm and I have to wait a long time for a red traffic light, to force the engine off. When the light turns green, I switch back to normal mode.
    That way the engine warms during driving, and not wasting fuel while standing still.
    Is this a good idea?
  14. efusco
    19,891
    1,194
    Nixa, MO
    <div class='quotetop'>QUOTE(Sho-Bud @ Apr 23 2007, 08:13 AM) [snapback]428250[/snapback]</div>
    Probably fine and a reasonable use. I've struggled over whether it's actually better, in the long run, to let the ICE continue to run and get into the next stage of operation during the initial warm-up even when not moving or to shut it off and let it do that while driving.
    I think the better/best use may be the times where you've maybe been at a long line for a stop light, traffic moves forward fast enough that you need to start the ICE to move up and not piss off everyone behind you. But your speed doesn't achieve the "magical" 35mph zone...often except in stage IV? the ICE will continue to run even as you come to a stop again when the light turns red before you go through it. That's when I hit the EV button. I know I'm warmed up, but I just didn't hit the programmed thresholds for the system to do it's usual quick shut off of the ICE...I know it'll shut itself down after about 5 seconds, but that seems like a long time when you're not moving.
  15. daniel
    14,487
    1,519
    Spokane, WA
    <div class='quotetop'>QUOTE(Sho-Bud @ Apr 23 2007, 06:13 AM) [snapback]428250[/snapback]</div>
    My feeling is that this is a good idea if and only if the battery SOC is high and the engine is warm. If the SOC is low, the engine will burn extra gas while driving to bring the SOC up, and if the engine is cold you want it to warm up anyway. So: cold engine and low SOC: let it run. High SOC: shut it off with the EV switch.
    I use the EV switch a lot when:
    The engine is warm and the SOC is high, but it won't go into electric itself because I have not encountered a long enough stop to get it into Stage 4 operation; and I am in a residential neighborhood with a lot of stop signs.
    Then:
    I allow the gas engine to run during acceleration, and then shut it off with the EV switch once I've reached speed. At the next stop sign, I start the engine again to accelerate back up to speed. This is easy to do because I have the Coastal EV switch, which uses the c/c stalk, which is right at my finger while driving, and I can operate it without taking my hand off the wheel or my eyes off the road.
