Lots of questions, if you can answer any that would be great.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Prius92, Jun 24, 2025.
  1. Prius92
    Prius92 Active Member
    519
    111
    Iowa
    Long story short, I rebuilt the motor and hybrid battery in my 2008 about 2 years ago, and then it sat due to a lengthy divorce. I put all new front suspension components (inner/outer tie rods, ball joints, wheel bearings, complete struts and sway bar links/bushings).
    While everything is now working fine, no codes, etc, there are still some issues now I can't seem to shake.
    1. The gas in the vehicle is roughly 2 years old, but since it's a sealed system, it seems to idle ok (doesn't misfire/die), but seems quite slow to accelerate. Would the old gas be the cause of this? I ran about 1/3rd of it out and put in fresh, but it made it only slightly better.
    2. The A/C seems to put a massive dent in the battery. When the dealership diagnosed the A/C and charged it, when I picked it up it was on the last purple bar. I was almost rear-ended because I was flooring it and it took like 30 seconds to go from a standstill to 45mph.
    No red triangle or anything. What would cause higher than normal power draw from the A/C compressor?
    3. I read somewhere if the battery gets too hot due to outside ambient temp, it will reduce the power of the battery to prevent over-heating. What is that temperature?
    4. I'm hearing kind of a bump/rattle in the front end going over bumps, but not feeling it in the wheel or brake, what could this be?
    5. Has anyone had the center console and arm rests reupholstered? If so, what did it cost?
    Main concern is slow acceleration.
    #1 Prius92, Jun 24, 2025
  2. pasadena_commut
    pasadena_commut Senior Member
    2,239
    665
    Southern California
    That is normal when the pack is going out. How was it "rebuilt"? New modules, old ones?
    Brian1954 likes this.
  3. Tombukt2
    Tombukt2 Senior Member
    12,136
    2,144
    Durham NC
    Pretty normal stuff clunking lower arms the rubber circle bushes that push into frame . Any components utilizing these type bushes they all broken now take a look . To check suspension requires a long iron bar like digging bar with that bar you can spread those bushes by tweaking on lower arms etc side to side up and down etc . The front end and frame shops are quite man handeling you vehicle whilst doing . You'd be very upset. To see it maybe.
  4. Tombukt2
    12,136
    2,144
    Durham NC
    Battery been addressed . Dump some good fuel on top of junk or hose in tank get old out . Fill it if you gonna drive it .
  5. Prius92
    519
    111
    Iowa
    Well there's no new modules being made for these except for Project Lithium (if they are even around anymore).
    I took all the modules out, charged/discharged them until the mAh reading is back to factory specs. I replaced probably half a dozen weak modules, voltage matched them, and installed new stainless bus bars (some fancy type that has the same resistance as copper).
    But the slow acceleration...it does it even when the battery meter shows 5 bars.
  6. ColoradoCrow
    ColoradoCrow Senior Member
    1,099
    455
    Leawood, KS
    I
    Have you checked your air filter? Cleaned the MAF? Try force charging the battery by putting car in Drive and pressing both brake and gas pedal at the same time. The SOC should rise to 3 blue bars in short order. I have replaced the arm rest and center console with vinyl fabric I got at a local shop. I bought some premade arm rest covers off ebay and spray glued them on to the plastic armrests. You will have to drill out the melted plastic rivets and when you put them back use short screws with a wide head.
  7. Hayslayer
    Hayslayer Member
    193
    103
    Do you have techstream? It will enable you to look at the current/power limits being imposed on the HVbattery for charge and discharge. Some phone apps will also do it.
    At low and high temperatures (and low and high states of charge iirc) the car will limit the power going into or out of the battery, but not provide any indication of an alarm or warning.
    This is usually displayed in kw as and will be a (+) or (-) value
  8. xw20_driver
    xw20_driver Junior Member
    46
    17
    PNW
    If you DIY, search "prius center console cover" on BezoMart and pick the fabric style and color. Pretty easy to do if you remove the console top. The screw to the latch release was a bit tricky to remove. I replaced the thread bare leatherette with a synthetic leather material in black so the elbow dirt didn't stain as easily as on the original beige cover. I used contact cement. Some covers include double sided adhesive tape. The cover I bought was under $5 off of Aliexpress pre-tariff era.
  9. Tombukt2
    12,136
    2,144
    Durham NC
    There are a few companies on the Asian sites that have this piece pre-made
  10. pasadena_commut
    2,239
    665
    Southern California
    Two years ago and then it sat. The pack is probably pretty far out of balance from just sitting that long with a set of modules which are different ages, different amount of use, different amounts of dried out, basically just not perfectly matched. Use Techstream of Dr. Prius to check how close the module voltages are.
    Toyota does make new modules for this pack, unless they stopped very recently. Buying a replacement set will cost $2k-$3k(ish) if you install it yourself.
  11. Tombukt2
    12,136
    2,144
    Durham NC
  12. Prius92
    519
    111
    Iowa
    A few other things.
    1. I semi-rebuilt the pack after it had sat, this was 6ish months ago, but did check in Dr.Prius at the time for any cells out of balance.
    2. When your going about 40mph and give it even a bit of gas, you hear this kind of sci-fi "whoot whoot whoot" noise, is this the CVT? Not a bearing or tire as it's only making that noise under throttle.
    The MAF and TB were ordered brand new/rebuilt from Dorman.
    At a green light, foot to the floor, it takes a solid 15 seconds to get up to 60mph.
    The battery seems to be doing better after driving it another 150 miles.
  13. Prius92
    519
    111
    Iowa
    This morning I went on a 60 mile round trip, when I left it was 81, when I returned it was 86 outside.
    The battery stayed around this state of charge 90% of the time, worst it got was down to 3 bars, but never turned purple.
    Def seems to be a heat related issue. Yesterday when I left to make a small trip, the car showed 102 outside in the parking lot, and the HV fan was running half the time as well.
  14. Tombukt2
    12,136
    2,144
    Durham NC
    The fan should be running in 102° weather that means it's 140 in the car till you blow that out put on air etc .
  15. Prius92
    519
    111
    Iowa
    Do you by chance know the temp the battery needs to reach to activate reduced power?
  16. Tombukt2
    12,136
    2,144
    Durham NC
    That's pretty normal to stay blue with the air conditioning running and good driving . It's not just battery overheating that . It's a combo of things going on . Inverter temps . Is pump. Running full resi etc the heat taxes everything electric. All the time even in ice car
  17. Tombukt2
    12,136
    2,144
    Durham NC
    I do not physically know the answer to that at all I Iwould say 120 plus . But then that's likely to trigger the hybrid system not charging inverter cutting power etc to save system .. I'm running in similar temps last 4 days . No issues at all all three being driven . In this heat I keep it to 65 ish AC on lo med hi fan and enjoy the cool drive . Not trying to kill it .
  18. pasadena_commut
    2,239
    665
    Southern California
    Record it and post it.
    If the fan isn't working right the pack will warm up and then the computers will tone down its use to prevent further overheating. Have you checked that the pack fan is clean, the air inlet isn't plugged up with dog hair, and that it can run fast and slow? The connector sometimes gets corroded when there is a leak from near the hatch hinge - water runs down into the electrical connector.
  19. Prius92
    519
    111
    Iowa
    So for whatever reason the battery is getting awfully hot.
    Everything else seems fine. Didn't do the "long test" but the short one and it passed other than the overheating.
    I even overrode the fan to run full time, it was only 78 out today and had the AC on full blast.
    Not sure if the "max charge" and "max discharge" are where they should be or not.
    I need to get to the bottom of why it's getting so hot.
  20. ColoradoCrow
    1,099
    455
    Leawood, KS
    I
    Is the hybrid fan dirty? Check the duct work mine wasn't sealed very well at the connections so I added HVAC Tape over the seams to increase air flow. That helped a lot. Maybe your fan seized up? I'd visually check the air flow at the battery.
