Louder horn?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by El Rey San Jose, Oct 19, 2011.
  1. El Rey San Jose
    El Rey San Jose Junior Member
    San Jose, Ca.
    Anyone have any info about installing a louder horn?
    Thanks, El Rey San Jose....
  2. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,515
    38
    Santa Fe, NM
    I put Sequoia horns in mine. Others have done Camry.
  3. SmellyTofu
    SmellyTofu Average punter
    251
    29
    Sydney
  4. charlesinoc
    charlesinoc meep meep :-)
    60
    San Clemente
    There is a very extensive detailed post on installing a louder horn Generation 3 prius. Do a search.
  5. samsprius1
    samsprius1 Active Member
    720
    182
    2023 Prius
    Limited AWD-e
  6. milkman44
    milkman44 Active Member
    591
    386
    Ky
    My wife totaled our '10 Mazda5 so I'm back to square 1 with a '10 Prius that replaced it. The horn on the 5 was as wimpy as the Prius so I'll be putting these on in a few days. It was an easy upgrade on the Mazda, just a small piece of wire and a couple of fittings to hook them together. Found them cheap here or at a store if you have Harbor Freight near you.
    2 Piece 12 Volt Electric Horn Set
  7. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    I have these in my Triumph. They are loud
  8. mtlewis
    mtlewis Tinkerer
    47
    Mississippi
    I put a stebel nautilus compact air horn on my Prius. They say it sounds like a Fiat. It is louder but not sure its worth the money.
  9. goodtimes
    goodtimes my future is righteousness
    67
    32
    2011 Prius Alpha
    I just put the Fiamm high/low freeway blasters that I copied from EVPV.... Easy DIY, but I had to remove all the plastic plugs on top of the upper grill to fit my fatass arm through... Other than that... Easy.... These suckers are loud too... More than satisfied... Thanks EVPV & El Rey San Jose on starting this thread!
  10. yyyiiikes
    yyyiiikes Junior Member
    84
    Austin, TX
    I had to use the stock horn for the first time today (car is 3 just days old)... a black Escalade didn't see me when changing lanes.
    Let's just say she was not impressed by the sound of protest issued from my car. And I was embarrassed.
    Just placed an order for the FIAMMs.
    Dylan Doxey likes this.
  11. DonVentura
    DonVentura SoCal Prius Driver
    78
    Ventura, CA
  12. alekska
    alekska Active Member
    435
    138
    Atl
    mtlewis,
    did you have to run a new wiring for Nautilus? Or have you used existing setup and just connected it?
    Thanks,
    - Alex
  13. jsmithy
    jsmithy Hypermiler and Freedom Lover
    75
    MO
    Stebel's require a relay. You can use the stock horn wires to trigger the relay, but the power has to come directly from the battery. As I recall, one draws ~18 amps.
  14. Maine Pilot
    Maine Pilot Senior Member
    166
    504
    Saco, Maine
    I've installed the Nautilus on my MX-5 (Miata). Our o.e.m. horns are much quieter than the Prius'--and we're a smaller vehicle. Installation is more difficult than on the Prius.
    The Nautilus does not require a relay--you can swap it out for your own horn without much difficulty. I'm not sure what the amp value of the Prius' horn circuit breaker is. Not withstanding JSMITHY's response, it may be the MX-5's c.b. has a higher value than the Prius.
    I've had two Nautilus' on two different cars and they both "died" after 18-24 months; possibly due to moisture. One fix is to spray some WD-40 into the horn's intake, but that gave only a temporary respite. Others on the miata.net have had good results with the horn, but given my experience, I'm ready for something else.
    I've decided to get a salvaged horn from a big honk'n American-made land cruiser as a permanent fix. Yes, it will need a relay, but it'll be worth the extra effort.
  15. ImeanGreen
    ImeanGreen Prius v Five BP Brigade #236
    547
    73
    Somewhere out there
    I was planning to install the Stebel Nautilus horn in my pri but the issue that I am having with them is it's reliability. They are really loud though.
  16. jsmithy
    75
    MO
    I use the Stebel Compact Nautilus on my dual sports bikes. I slip a piece of clear fuel tubing over the intake and run it up into a "clean" area, usually under the seat, so water/dirt/mud doesn't enter the intake. Three years later they have not failed yet. I also slip an old sock over the whole horn when lots of dust or mud is involved to protect the outlet.
  17. mtlewis
    mtlewis Tinkerer
    47
    Mississippi
    Alekska,
    Sorry, haven't been on for a while. I just ordered the wiring kit that Amazon offers for the horn. It includes a relay but my horn came with a relay also. It would be better to use the relay and wiring kit because the Stebel draws more amperage than your stock horns.
    That being said I have since changed my horn again. This time to the Fiamms offered on Amazon I think.
