Low beam and fog HID together?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by hlkc, Feb 13, 2010.
  1. hlkc
    hlkc New Member
    229
    US
    Anyone have low beam and fog light in HID? I'm going to do 6K low beam and thinking if I do that mine as well to do the fog light too. But if I turn both on, it will be cops magnetic... Also, not sure will that be too much electricity when I have both on. What do you guys think? Anything I also need to consider? Please advice.
  2. JimboPalmer
    12,470
    6,875
    Greenwood MS USA
    So you know it is illegal, and will annoy others so bad you plan to be ticketed, and you want our advice? Mine is "Buy some other car, Prius owners are getting enough bad press."
  3. ABL
    ABL Member
    163
    30
    San Jose Ca.
    I thought High Beams + Fog Lights were illegal in Ca. Not Low Beams + Fogs. Is this correct or are HIDS a special case?
    Jim
  4. JimboPalmer
    12,470
    6,875
    Greenwood MS USA
    No 2010 in the US is sold with HIDs, just halogens and LEDs. Since it is not legal to convert between types according to the NHSTA, a 2010 with HIDs has to be illegal, high beam or low beam. (It is not legal to make a bulb that plugs into a socket not intended for that type bulb)
    My 2009 Prius was purchased with HIDs and fog lights. You can only run the fogs with low beams, stock.
  5. SDM44
    SDM44 SeƱor Member
    199
    38
    Los Angeles
    On all US cars, you are supposed to only run the fog lights with your low beams, and not with your high beams. That's why on all cars that have factory fog lights on them in the US, they turn off when you turn on your high beams. You can modify this so the fog lights stay on with the high beams (euro-spec) by hard wiring it, or possibly via the software with something like a ScanGaugeII.
  6. Tideland Prius
    16,402
    really? I mean it's illegal everywhere to convert to HIDs but I don't think you get pulled over for having both on (unless they were both blue or your local police force is really strict). You could always do yellow fogs.
  7. sti-nkr
    sti-nkr Prius Ricer
    45
    Tyler, Texas
    Thats why I love texas. HID lows, highs and fogs. no one cares.
  8. shawnb2
    shawnb2 Active Member
    533
    107
    22
    Thousand Oaks, CA
    First of all, the headlights are projectors so there is a much better cutoff for the light compared to a conventional halogen setup. Blinding oncoming traffic is going to be much more difficult because of the cutoff. Second, HID's have a very low amperage pull as they use a ballast to up the voltage to light the bulb. Much more light with less wattage equals better efficiency. Last but not least, foglights are meant to run with low beam headlights. High beams are usually the no-no. I personally think you and others are being to much of a worry wart when it comes to this. I have 6000k HID's in place for my fogs and just adjusted them properly. They reflector is for more of a wide beam as opposed to straight line so as long as they are adjusted properly you shouldn't have any problems. I'd just do it. Just what ever you do, if you decide to tint your tail lights don't ask for opinions here. Causes way too many problems. Wasn't me, but I've seen it happen.
  9. Tideland Prius
    16,402
    Depends on county I guess. Some police agencies are stricter than others. Also, fogs should be run with the parking lights only for maximum effectiveness in, well, fog.
  10. shawnb2
    533
    107
    22
    Thousand Oaks, CA
    Sorry Tideland, but I have to disagree. Besides I would say 85% of the cars that have factory fog lights don't allow the fogs to be on without the headlights. You still need to see straight ahead which is what the low beams offer. The fogs are a wide beam to light the sides of the road to see markers and the like so you are sure to stay in your lane. Not to mention that is another reason why true fog lights are yellow in color. The color reflects better which means you can see it better in foggy situations. White lights are typically just a driving light just to help light up the road directly in front of the car.
  11. Tideland Prius
    16,402
    85%? More like 100%. It's because the rules here dictate that foglights MUST come on ONLY with the low beams.
    You can't see straight ahead if you're in dense fog. Low beams will just fog up (no pun intended) your vision as the water particles reflect the light back creating a wall of light just ahead of your vehicle (it's worse with high beam). Like you said, the fogs are a wide beam to illuminate the sides of the road so you can see the markers and yes I agree, yellow works better.
  12. SDM44
    SDM44 SeƱor Member
    199
    38
    Los Angeles
    I just noticed this with the Prius the other night when I changed out the fog light bulbs. At least on my BMW you can run the fog lights with the parking lights and no headlights. There's a mod out there that works on most cars, and it was the same for my 2006 Audi, where you can to hardwire the fog light signal wire to the headlight wire (very easy mod, just snip & tap 1 wire). I assume it's the same way on the Prius... 3 wire switch, only the wires are on the column and not a separate fog light switch off to the side (which made the Audi mod much easier). Just look for the parking lights power/signal wire with a multi-meter and find the fog light signal wire. Cut the fog light signal wire and tap into the parking light power/signal wire, so the fog lights will work when the parking lights are on (since it will see the signal). Putting it back is as simple as removing the circuit node (tap) and connecting it back to the cut wire.
    That'll be my next weekend project. I just need to figure out if I can access everything from under the dash/steering column, or if I need to remove the steering wheel to get to the headlight stalk.
  13. hlkc
    hlkc New Member
    229
    US
    Can you give me some ideas how to adjust them? I thought after I put them in and there is no adjustments at all. Thanks.
  14. edh53
    edh53 Junior Member
    ohio
    I am afraid I disagree with the above comment about the purpose of fog lights being to light up the margins of the road. The difference in fog lights is the angle of the light relative to the roadway and the resulting reduction in "bounceback" of light from the fog, as is experienced with low beams (and even more so with high beams). This is why fog lights are mounted so low on the front of the car.
    The result is that, while they light the road less well, true foglights do not produce that glaring light reflection that makes driving at night in the fog so difficult. If they can only operate when the low beams are on, as on my 2005 prius, the benefit of foglights is defeated. To me it is poor engineering. Perhaps if the toyota engineers woudl drive a mercedes for a spell they might catch on to this.
    To experience the benefit of true fog lights, the next time you are alone on a road at night in heavy fog, or in a blinding snowstorm, IN A CAR THAT UNLIKE THE PRIUS HAS BRIGHT PARKING LIGHTS, try momentarily operating on just the parking lights instead of the headlights, and you will notice that, paradoxically, you can see much better and expereince much less glare/bounceback. If you can see any other traffic, DO NOT ATTEMPT THIS.
    What is needed is a mod that allows for driving (at slower speeds, as is always called for in poor visiability conditions) with only the fogs and parking lights but no headlights. If anyone knows of such a mod please let me know (I cannot quite seem to find it by searching this forum, but I know it's out there somewhere). Thanks all.
  15. Tideland Prius
    16,402
    edh53, part of it is due to regulations. Low beams must be on when foglights are on (I guses the DOT would call them driving lights??). That's why they can't be operated without low beams. Of course there are a few loopholes (e.g. if the car uses fogs as DRLs, then you can technically run them without the low beams) and a few cars can operate the fogs without the low beams (e.g. smart fortwo). Not sure how they got away with it.
