Low cost LED interior Light Kit
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Xaran, Sep 13, 2012.
  1. Xaran
    Xaran Junior Member
    95
    I dont have any association to this seller. I just wanted to pass on what I think is a good deal on a LED package for the Gen III interior lights.
    I got this off E Bay, all bulbs fit perfectly and a much brighter and whiter than stock. I changed the front and rear dome lights, rear interior lift back and all doors. It also had 2 extra bulbs in the set so I have spares.
    6 x White LED Lights Interior Package Deal Toyota Prius | eBay
    abonnema and JAYSONE like this.
  2. abonnema
    abonnema New Member
    Just bought them, looks like a good set. Thanks!
    Xaran likes this.
  3. PriusGuy32
    1,417
    513
    Harrison Township, Michigan
    Thanks for this tip!! Its been bugging me that the interior bulbs werent LED from the factory, but w/e. Im going to swap the old style out for LED's, that way if I accidentally leave the interior lights on one night I wont be left with a dead battery!
  4. xliderider
    xliderider Senior Member
    8,016
    3,198
    Honolulu, HI
    I bought from that seller as well. However, the bluish LEDs started to bug me after a while. So I replaced them with "warm" LEDs that give off a slightly yellowish light (like the stock lights) and for the dome, I got something like this:
    36 LED 5050 SMD Warm White Car Interior Dome Light Panel T10 Dome BA9S Adapter | eBay
    It gives off much more light than the one in the kit you linked. You can get these panels in the standard bluish LEDs too if you want. ;)
    Tracksyde likes this.
  5. Fore
    Fore Don't look back!
    494
    107
    Bought these awhile back too, can't beat the price. VERY BRIGHT! tight fit on a couple of areas but well worth the frustration.
  6. xliderider
    8,016
    3,198
    Honolulu, HI
    Yeah, I couldn't get the bulb for the dome in. I had to use the shorter one intended for the hatch.
  7. kmkremer
    kmkremer Member
    227
    30
    San Diego
    Questions: These will fit the two map lights in the front and the dome light in the rear seat area, right? What did you do for the door lights, visor mirror, cargo and license plate lights? I want everything to match if possible.
  8. Xaran
    Xaran Junior Member
    95
    Contact the seller. He was very good service with me. 2 of the bilbs were a little long so he sent the shorter versions and they fit perfectly.
    I was able to change the 3 dome lights (2 over driver and one over rear seat) bottom of doors and the rear hatch light on the left side back
  9. xliderider
    8,016
    3,198
    Honolulu, HI
    Yeah, I also had to contact the seller for another shorter bulb. The one intended for the dome light was too long to go in.
