Low Engine Oil Pressure Advice
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Shrektangle, Dec 29, 2024.
  1. Shrektangle
    Shrektangle New Member
    Hello, I’m new to the forum,
    About a month ago my 2013 Prius (180k miles) briefly flashed the low engine oil pressure light along with the yellow caution light. It was super quick and I wasn't totally sure I'd seen it so I left it parked for a few days. When I came back to it the warning came on and stayed on so I had it towed to my mechanic. The mechanic didn't have a clear answer for me other than that the P0300 general misfire code had registered for him.
    I replaced the spark plugs and ignition coils and made sure the oil was still full and the car ran fine for 3 weeks just with normal driving never really going for more than an hour. I had hoped the issue was fixed but then driving around town around 30 mph the light came back on the day before I was supposed to leave for a road trip.
    I did some reading and hoped perhaps it was the oil filter so I changed the oil and filter (it had been about 8k miles) and hoped for the best. The next day I drove south about 700 miles mostly downhill without any issue and the car felt great, got good mileage, and ran smooth. I did some light driving the next few days and then the despised light came back on. I checked the oil level and it seemed to still be full, there were no signs of leaks, and as the car has sat the last few days it has stayed full.
    I bought a basic OBD2 scanner and it read no codes no issues and I’m out of ideas. I’m hoping that the oil pump is not the issue and alternatively I’m not sure how to check if my sensor is bad. I’m hoping to get it into a mechanic in the next few days but wondered if there's any sage advice I can get here.
    I haven't noticed any oil leakage or smelled any oil burning. Sorry if there's too much detail I figure more info is better than less.
  2. BiomedO1
    BiomedO1 Senior Member
    2,578
    1,387
    SacTown, Ca
    A basic OBD2 scanner isn't going to tell you anything, you need a scanner that's able to read the sensors directly. That way your looking at whatever the computer is seeing. You may have a bad oil sensor, but you'll need to test it and place a manual oil gauge on it to verify accuracy. It may also be bad oil. What kind of oil are you using? Are you using a quality, full synthetic 0w20 oil?
    I've had oil break-down on me, but that was 40 years ago. Was using 30 wt oil, when I did my oil change - it drained out like water @ just 5K miles on it. Switched to Castrol and never had that issue again. When I inherited my dad's truck, had low oil pressure when hot and idling. Did an oil change with Castrol oil - no more issue. Later found out it was Jiffy Lube oil, so whatever cheap stuff they're using isn't good for any engine - IMHO......
  3. Shrektangle
    That's good to know about the OBD scanner thank you. I used a full synthetic 0W-20 oil and I can't remember exactly what brand it was but think at least not the cheap stuff. Not sure if you can tell oil breakdown by the look of it but when I've been checking with the dipstick it looks pretty clean.
  4. PriusCamper
    PriusCamper Senior Member
    11,856
    4,806
    Pacific Northwest, USA
    For Gen 3, at 180K miles, usually you'd be at the stage of the high-MPG piston rings failing and burning oil. How has the oil level been? Are you up to the one quart loss per 1000 miles yet?
  5. Brian1954
    Brian1954 Senior Member
    1,567
    607
    South Central PA, USA
    A Gen 3 Prius only has an oil pressure switch. The oil switch is either open or closed, so a scanner will not tell you anything more than what the low oil pressure light on the dash can do. The only way to see the actual oil pressure is to add a pressure gauge or pressure transducer.
  6. Mendel Leisk
    40,238
    You don't sound 100%. Could you see a definitive top-of-oil, or it was smeared so much you're not sure. Check on level ground, and after pulling/wiping the dipstick, wait 5 minutes before reinserting for the check. The dipstick is prone to pull oil up the tube, make it difficult to discernt the true oil level. Your year will for sure have the low-tension piston rings, more prone to oil consumption, fwiw.
    Ever cleaned the EGR system?
  7. Shrektangle
    I haven't noticed the loss of oil yet. Would burning one quart be enough to trigger the low oil pressure light?
  8. Shrektangle
    On my initial look at the oil I wasn't super sure, but I thought it might have been low so I topped it off with a quart of oil. On the drive home the alarm flashed again and since I've left it the past several days I've checked the oil more than once and can see it's full.
    I haven't ever cleaned the EGR system and to be totally honest I’m not sure what the EGR is. Is it an involved process that I should leave to the mechanic or can I do it from home?
  9. rjparker
    rjparker Tu Humilde Sirviente
    9,299
    5,667
    Texas Hill Country
    The low oil pressure switch is easy to change and relatively low cost. Access by removing the passenger's front wheel and an access panel in the wheel well plastic.
    Brian1954 likes this.
  10. Leadfoot J. McCoalroller
    7,766
    7,243
    Pennsylvania
    2018 Prius c
    Have a real oil pressure test done, then use those results to decide whether the oil pressure warning sensor is throwing false alarms or if your engine is actually worn out.
    BiomedO1 likes this.
  11. PriusCamper
    11,856
    4,806
    You'd need to be more than 2 quarts low on oil for that to be the source of the problem.
  12. Grit
    Grit Senior Member
    6,367
    4,155
    Wilkes Land
    Bam!!!
  13. PTS
    PTS Member
    71
    33
    Austin, Texas
    2013 Prius v wagon
    Low oil pressure light means no oil pressure which means no oil. When you say "...I wasn't super sure, but I thought it might have been low so I topped it off with a quart of oil" that sounds like a dribble of oil on the dipstick caused by the curved holder. It has to be solid but normally only on one side of the dipstick.
    OR the light is actually something else which has been the case in the past.
    What the egr has to do with it is beyond me.
  14. PriusCamper
    11,856
    4,806
    most people think oil pressure warning light (imminent engine failure) is actually just the low oil warning light. We have an ongoing campaign to raise awareness about knowing how to check your dipstick but we are failing so often... :'-(
    It seems more an issue in Gen2 Prius age cars right now, but gen3 is on the horizon.
  15. BiomedO1
    2,578
    1,387
    SacTown, Ca
    If he "topped it off", with a quart of oil and it's now full - the car was down a quart. Otherwise it should be way over filled NOW; if oil was touching the stick to begin with! He needs someone else to verify his work or what he's seeing. A gen3 with 180K, would be burning a significant amount of oil - at least a noticeable amount.
  16. Grit
    Grit Senior Member
    6,367
    4,155
    Wilkes Land
    Best reply describing the permanent issue.
  17. Grit
    Grit Senior Member
    6,367
    4,155
    Wilkes Land
    User oil mismeasurement issue eh?
