Magic eraser to clean of bugs, tar, etc.
Discussion in 'Gen 2 Prius Main Forum' started by ski.dive, Oct 13, 2010.
  1. ski.dive
    ski.dive Active Member
    958
    241
    Hutchinson Island,FL. Mt. Snow,VT
    Who has tried the 'magic eraser' pad to clean the prius?
    It gets rid of bugs, tar, etc. With just a simple wipe.
  2. ski.dive
    958
    241
    Re: Magic eraser to clean off bugs, tar, road grime,etc.
    the magic eraser will get rid of the bug, tar and many other of your car stains.
    inside and outside of the car
    i use it all the time.:):):)
  3. Bob64
    1,540
    93
    Virginia
    Isn't it an abrasive, like the equivalent of high grit sandpaper?
  4. Anthonyjordan
    Anthonyjordan New Member
    23
    Long Island, NY
    You are correct and it can and will dull the clearcoat. I have used the Magic Eraser on many things with success but I have seen it take the sheen out of Vinyl, plastics and other materials. Use with caution and in a small test area if you are set on using it.
    I wouldn't use it on a any car's clearcoat. Especially the clearcoat on the Prius which is not great at all. My friend owns an autobody shop and he said that the paint job on the Prius is the equivalent to a Macco job. The paint job has been one of the only sore points for me in terms of satisfaction.
    Try using Wd-40 on a soft microfiber rag and watch the results you get. Wd-40 wont harm your clearcoat.
  5. SW03ES
    SW03ES Senior Member
    2,480
    176
    Gaithersburg, MD
    Absolutely never use the Magic Eraser on the paint of the car. It is very abrasive, and has a bleach-like cleaner that will scratch the paint for sure. May as well use a brillo pad.
    Works great for rough vinyl and plastic, such as in a lot of interior applications...but not the paint.
  6. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    I use them on my boat to remove spider droppings and hand print dirt. They work very well on this sort of painted surface, but the paint on the boat is going to wear off anyway and be repainted on a regular basis. I don't think you want to do that with the shiny paint on your car.
    Tom
  7. krg03
    krg03 Not expert, just experienced
    246
    31
    so cal
    Keep a good wax job on your car and use any detailer shine product. Usually cheap by the gallon. Spray it on, wipe off the bug. Works very well. No "sanding" with an eraser. What buck you save in something cheap will pay for later in a paint job.
  8. SW03ES
    2,480
    176
    Gaithersburg, MD
    Paint on a boat is a gel coat too, vs the paint on a car. I wouldn't be worried about using them on a boat for the very reasons you mention.
  9. qbee42
    18,058
    3,076
    Northern Michigan
    You assume too much. There isn't a bit of gel coat on our boat. Plastic is for bleach bottles. Real boats are made of wood.
    :p
    Tom
  10. SW03ES
    2,480
    176
    Gaithersburg, MD
    Ah! You got me!
    You are a man of marine class sir :D
