Main traction battery possibly failing?
Discussion in 'Gen 2 Prius Main Forum' started by dgw, Nov 1, 2007.
  1. dgw
    dgw New Member
    38
    Mill Valley, CA
    I bet that someone here has the experience to tell me what a failing battery would behave/look like.
    I have 52K miles over 3 years and have been noticing that the battery now fills up (all green) easier and faster than before, and also depletes (down to 3 or 2 bars remaining) faster than ever before. Also, my mileage has been decreasing noticeably although not drastically, even though I drive slower than ever on the freeway (down from 65-70 avg to 60 avg) and have gotten pretty good at maximizing mileage, having driven Prii for 4 years and 75K miles.
    Is this consistent with a NiMH battery starting to lose its ability to recharge? If the battery is failing, at what point would Toyota consider it a warranty issue?
    Thanks to all, for the collective wisdom I have gotten from this forum over the years.
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    Dramatic swings in the battery SOC can be a symptom of battery failure. But typically this starts to become evident over a pretty short time period and the swings are, indeed, dramatic usually dropping quickly from green to pink in a matter of minutes.
    Since you have a lot of time behind the wheel I'm inclined to think that there may, indeed, be a problem. Now, I'm not sure if Toyota can/would help yet or not. I think that if you know your service dept. well and/or the hybrid tech that usually works on your car that it would be worth while to take the car by and ask them to take a look. I would think that the hand-held tester could look at the battery voltages and such to determine if it has been 'behaving badly'.
  3. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    <div class='quotetop'>QUOTE(efusco @ Nov 1 2007, 01:15 PM) [snapback]533444[/snapback]</div>
    This is why it's good to bring your Prius tech a coffee and bagel every now and then
  4. David Beale
    David Beale Senior Member
    5,963
    1,985
    Edmonton Alberta
    The THHT can tell if any module is failing. They may want to charge you to look unless the car is complaining (MIL or CE light on) or unless they find the battery is indeed going bad. The car will throw a light once the battery gets bad enough. At least, some of the time.
    It's not just because the outside temp is falling? With use, the battery can accept/deliver power faster. Though this usually is seen after a few months rather than years of use.
  5. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,000
    Fort Lee, NJ
    Toyota defines the end of life for the HV battery pack when the capacity falls below 80% of the original.
    Falling MPG could be due to other causes, such as engine air filter.
  6. eestlane
    eestlane Member
    110
    Space Coast, FL
    Most of us on this forum seem to forget that the traction battery contributes very little to the energy used in fairly level ground freeway driving. Most all of the fuel savings is due to the Atkinson cycle gasoline engine. The battery and electric motors are used mostly to get the car moving, since the Atkinson engine has poor torque from start-up. Of course, some savings are contributed by the occasional use of brakes and the consequent regeneration. So, to understand the loss of gas mileage in freeway driving, look for other reasons besides the traction NMH battery.
  7. efusco
    19,891
    1,194
    Nixa, MO
    <div class='quotetop'>QUOTE(eestlane @ Nov 1 2007, 02:35 PM) [snapback]533513[/snapback]</div>
    While I would normally agree with you if the OP had said that the only reason he was concerned about the HV bat was b/c of the dropping MPG when that data is combined with his (admittedly vague) description of the battery SOC display behavior there is cause for concern.
    I grant that the cooler weather may be the cause of all this, but a driver with 4 years of experience with the Prius should be familiar with the seasonal/temperture variations and normal battery SOC behavior and if he's noting a pattern I'm going to presume, for the time being, that there may be an issue, esp. since the few well reported cases of battery failure that I've heard report the dramatic swings in SOC just prior to full out failure.
    Also, while the main job of the battery is what you describe it also acts as a buffer for energy even at steady state highway driving...an alteration in that buffering ability could account for a small but measurable change in FE on the highway and a moderate to significant drop in FE under rural/city conditions.
  8. eestlane
    eestlane Member
    110
    Space Coast, FL
    Dr. Evan, I yield to your (as usual) astute and well thought out analysis. A failing traction battery may well cause the system to try to charge it, with less than normal results, resulting in an increased load on the ICE and consequently lower gas mileage.
  9. galaxee
    galaxee mostly benevolent
    9,810
    468
    MD
    well, the OP does not mention maintenance done to his vehicle. dgw, let's talk about other possibilities first. what kind of maintenance has your car gotten so far?
  10. dgw
    dgw New Member
    38
    Mill Valley, CA
    My experience is that on first start of the day, when the battery is cold, the swing from top to bottom can happen really fast, like seconds. But not always. The onset of colder weather (although we're talking San Francisco bay "cold") seems to amplify the effect somewhat. One example I can give was this spring at Yosemite, parked for the night the battery was fully green at 65 degrees. It was just below freezing the next morning and climbing out of the valley, the charge dropped from green to 2 bars in less time than it takes to type this sentence.
  11. efusco
    19,891
    1,194
    Nixa, MO
    <div class='quotetop'>QUOTE(dgw @ Nov 2 2007, 12:58 AM) [snapback]533736[/snapback]</div>
    But that was in the spring and climbing.... If you were having a battery failure that long ago it would've been done by now. That said, swings in 'seconds' is not normal at all.
  12. dgw
    dgw New Member
    38
    Mill Valley, CA
    <div class='quotetop'>QUOTE(David Beale @ Nov 1 2007, 01:48 PM) [snapback]533457[/snapback]</div>
    I replied above to EFusco that there does seem to be a temperature component to this, but where I am (SF bay) the seasonal temperature swings are pretty minimal. The car is garaged at night and its rarely colder than 50 in there.
    <div class='quotetop'>QUOTE(efusco @ Nov 2 2007, 02:01 AM) [snapback]533738[/snapback]</div>
    Wow you're fast on the reply. I've been out all day and just got back to the computer. Anyway, in that example, the sudden drop happened just as we started off the flats, so the amount of climbing was about 5 or 10 seconds worth when I looked down and was shocked to see 2 bars where 15 seconds previous had been solid green. Still, if as you say the failure happens suddenly, then it should be much worse by now, and its not.
  13. dgw
    dgw New Member
    38
    Mill Valley, CA
    <div class='quotetop'>QUOTE(eestlane @ Nov 1 2007, 07:08 PM) [snapback]533600[/snapback]</div>
    I live at the top of a steep hill and when the battery drops to 2 or 3 bars the gas consumption goes from 11-12mpg to 7-8mpg. I attribute that to the ICE doing all the propulsion duties as the SOC computer takes the battery offline to protect the remaining charge. I hadn't noticed this happening before this year and its pretty obvious as the engine note becomes much harsher and strained. Also there is much less power. Interestingly, if I floor it, the electric system will supply additional power. One of the benefits of a parallel hybrid over a series hybrid I suppose.
    The flip side of depleting the battery on the trip up the hill is that it is much more likely now to be fully green before I get to the bottom of the hill. So often, in fact, that I regularly use B mode to reduce friction braking and hopefully avoid completely filling the battery. One odd feature of the Prius is that when the battery is full, rather than shutting the ICE off and burning off the excess electrons through the electric motor it does the opposite and runs the ICE at really high rpm. Don't know what that is about, but it does knock the mpg avg down, when I would have thought that a fully green battery would give fabulously high mpg.
  14. dgw
    dgw New Member
    38
    Mill Valley, CA
    <div class='quotetop'>QUOTE(galaxee @ Nov 1 2007, 07:17 PM) [snapback]533604[/snapback]</div>
    Pretty much the normal scheduled maintenance from the local Toyota dealer. The only thing I can think of might be the 50P ECU reflash recall 2 years ago. There's absolutely no doubt that that hurt my mpg avg. Prior to that I could always, always get 50 to 55mpg on the freeway, and sometimes over 60mpg. Since the 50P, I barely get 50mpg and never get close to 60mpg. Other than that, I've had the alignment checked and even though its not quite up to spec on the rear, they didn't fix it b/c its not something that can be adjusted. Which makes me wonder why bother to have any specs for it. Anyway its not much off so I haven't worried about getting it fixed.
  15. galaxee
    9,810
    468
    MD
    ok. well as far as battery replacement goes, toyota will not replace an HV battery until they have a DTC that indicates a problem with it. if you saw failure symptoms, you'd be seeing a DTC.
    one thing you might try if you've got a friend in the local service department is to ask them to do the battery equalization procedure. they do this with used hybrid cars before they get sent back out to the lot. it's in the scantool in either the HV or the battery computer menu.
    otherwise, anything about your commute change lately? that's a common one that DH had to explain all the time.
  16. whiten
    whiten Junior Member
    Littleton, CO
    What ever happened with this?
    I am having the same symptoms. 78K miles; my commute goes up and down lots of hills (live in Denver and commute up and down the foothills). Battery SOC goes up and down *much* faster than when it was new. Many times now I'm at full green at the bottom of hills and the ICE runs to remove overcharge, or down at one line and running fully off the ICE.
    Gas mileage per tank is about the same over the last 25k miles, but I've learned how to drive it for better efficiency. Slowly my MPG has increased on the commute from about 47MPG to 52MPH. I can do the full round-trip commute at >57MPG, but it's the little stuff around town that drops the mileage per tank. However, my suspicion is I'd do better if the battery was "new."
    I've taken a lot of road trips to with the car, and in February, I came west across Kansas and only got 33MPG. I'm used to much more like 42 on the highway, so that was a noticeable drop. I've driven that stretch twice before and gotten 42MPG or better. I did not notice a wind this trip, either driving or when stopping for fill ups, food, or other stops. So it was weird.
    All this is to say, I'm thinking of taking the car in for a "battery capacity test" before the warranty goes away. I was told once by a Toyota mechanic that they don't have such a thing, which both surprises me and doesn't surprise me. It surprises me because it's what should be done (I'm a EE and do satellite work, and battery capacity testing is integral to making sure we have good batteries before sending a satellite into space that *needs* good batteries) to tell how if the cells are behaving properly; but also not surprised because they could end up replacing a lot of batteries that otherwise might "get by."
    I feel that Toyota engineers have done a GREAT JOB on their algorithm for controlling the battery state of charge, but at the same time, batteries don't last forever, and I've been skeptical since I bought this car that I would not see significant battery degradation before Toyota wanted to admit something was wrong.
    Please don't take that as a negative against Toyota or the Prius. I LOVE the car, and would get another in a heartbeat if I could afford it.
    Anyway, all that is bit of a ramble, but back to this thread, what ever happened? Comments anyone?
  17. donee
    donee New Member
    2,956
    197
    Chicagoland
    Hi Whiten,
    I can see a drop from 5 bars to 2 in cold weather, during the first minute of operation. That is normal. It because I have a small hill to climb, and I forget to take it slow sometimes. The cold start routine of the Prius keeps the engine at reduced power and uses electric drive for the first minute. Thus the dramatic battery change during this time. Especially with cold tires. I actually know the point in the road where the system switches. Because I can push the throttle at that point, and rather than the yellow arrow (discharging), I get a green (charging). This point in the road is only about 1/8 of a mile from the starting point, and reportedly, its 57 seconds from startup.
    If you want to baby the battery, then let the car sit for a minute before driving away. This way the cold start routine will be out of the engine low-power time.
  18. tochatihu
    tochatihu Senior Member
    9,456
    3,654
    Kunming Yunnan China
    2001 Prius
