Maintenance Required Light Out of Sync.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by stuhillman2004, Mar 19, 2005.
  1. stuhillman2004
    stuhillman2004 New Member
    53
    Limousin France
    I had the E010-04 modification done - including replacing the guage package. Now the Maintenance Required light is out of synchronisation coming on at 22,500 miles instead of 24,500 miles as it should have done. The dealer tells me that they know of no way to put it back in sync! Thanks to the postings on this site, I know how to turn it off but, surely, some of you brainy types out there have figured this one out. Right? :mrgreen:
  2. mspencer
    mspencer New Member
    101
    Council Bluffs, Iowa
    I think the only way to correct it is to do the reset procedure again when you do the next oil change, even if the light isn't lit.
    (Prius techs: will that work? If you attempt to reset the oil change reminder when the reminder isn't even lit, will it actually reset the counter, or will it do nothing?)
  3. rick57
    rick57 Member
    572
    Circleville, Ohio
    <div class='quotetop'>QUOTE(mspencer\";p=\"73895)</div>
    Yes that will work. Next oil change just reset the oil change reminder light. It will reset the mileage driven calculations in the Meter ECU (inside the Combination Meter , speedo assembly if you will) so you should be back in sync. 8)
  4. stuhillman2004
    53
    Limousin France
    Damn - you guys are good!
  5. rick57
    rick57 Member
    572
    Circleville, Ohio
    <div class='quotetop'>QUOTE(stuhillman2004\";p=\"75581)</div>
    Aw,shucks. Twernt nothin' :oops:
  6. Tideland Prius
    16,401
    Rick, I have a problem with my maint req'd light. (I posted it in a new thread). I'm at 7,700kms and I haven't seen that light. I should've came on 500kms ago.
  7. DanMan32
    DanMan32 Senior Member
    3,799
    27
    Tampa Bay, FL
    If I understand it, Canadian models don't have this feature.
  8. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Ditto. Canadian market Prius do not have the maintenance reminder light.
  9. rick57
    rick57 Member
    572
    Circleville, Ohio
    <div class='quotetop'>QUOTE(jayman\";p=\"75710)</div>
    Hmm? Didn't know that. Guess I learned something today, :)
    But maybe I don't need to know it unless I moved to Canada!
  10. DanMan32
    3,799
    27
    Tampa Bay, FL
    That and bought a Prius over there.
  11. Tideland Prius
    16,401
    I toured Foothills Toyota today. I can't believe the Avalon Limited isn't available in Canada (XLS is our range topper). They left the smart key in the car so I could start the car and play with the goodies. Our Prius doesn't have the nav so I took the opportunity to try that out. Where's our smart key? hehe.
  12. geckoboi78
    geckoboi78 New Member
    53
    Va Beach, VA
    do you have to fill in all of the info under the maintainance menu in order for the computer to remind you to take the car in?
