Major issues and resolutions
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by srivenkat, Mar 20, 2011.
  1. srivenkat
    srivenkat Active Member
    596
    93
    IL
    Hello All,
    I became a proud owner of a used Prius last month and one thing I started looking for is a list of major issues and (potential) resolutions. Since some of the Toyota TSBs cover certain issues under certain warranties, I have been anxious to get a list of things I should check my Prius out for so I can get them resolved before the warranties expire.
    So far, below is a limited list of issues I have gleaned from the limited time I spent on the forum:
    1. Brakes do not work properly in certain snowy situations?
    - TSB fix?
    2. Rear hatch struts do not work properly in colder climates?
    - TSB fix?
    3. Rattle noises on some Gen3 Prii?
    - no known fix?
    I would appreciate additions/modifications/deletions which I promise to edit this post with for the benefit of new/existing owners.
    If this post generates enough info, perhaps the moderator would be inclined to make this sticky.
    Thanks much.
