Making a 12V starting battery out of Prius individual cells?
Discussion in 'Gen 3 Prius Technical Discussion' started by 5 Speed, Sep 17, 2017.
  1. 5 Speed
    5 Speed Member
    74
    83
    Santa Barbara
    I just purchased an optima battery to replace my original 2011 12V battery because with 150K on the vehicle and I am the third owner I decided that it is a good time to reduce the stress. Yes it is still working and even with my scan gauge it can put out 12V with the headlights on before starting the vehicle it is time. But it got me thinking that with so many single used cells from the original battery packs for sale on eBay would it be possible to just wire two 7.6 volt batteries in series and have a lithium ion starting battery? I bet with a little work I could make a custom plastic holder to nest two batteries and install.
    50,812
    not sure how it would handle the charging software, or how safe it would be.
  3. Prodigyplace
    12,366
    11,661
    Central Virginia
    Likely not safe at all. NiMH and lead acid batteries require different charger behavior.
    If you want an idea of what can happen with the incorrect charger, look up the "hover board" & laptop fires that were in the news a while back. They used different batteries than what we are discussing here, but the risk may be similar.
  4. Grit
    Grit Senior Member
    6,367
    4,155
    Wilkes Land
    What will happen to car's warranty?
  5. StarCaller
    StarCaller Senior Member
    1,267
    718
    Cedar Crest, NM, USA
    gets extended 5 years/
    Grit likes this.
  6. Brian in Tucson
    Brian in Tucson Active Member
    981
    453
    Tucson AZ
    2003 Prius
    KISS--Keep It Simple, Stupid!
  7. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,080
    Columbia, SC
    Not advisable. The nominal voltage of two in series HV modules is 14.4 volts, but in reality its more like 15.6 volts. The inverter may not even keep it charged. The capacity of the modules is 6.5 aH. The capacity of the normal 12v AGM aux battery?....isn't it 46aH for the sks system cars and 34aH for the non-sks? You would need several pairs of modules in parallel to get equivalent capacity.
    The HV modules also need to be under compression when charged to prevent bulging. Throw in the possibility of the terminals shorting against other components and on and on and on...
    Way to many possible problems to seriously consider it.
    Now, it you want to have some type of cheap emergency power just to energize the electronics long enough to get the car started, that may be a different story. But, (2) 6 volt lantern batteries may do the same trick.............I may have to try that just for fun........
  8. Brian in Tucson
    981
    453
    Tucson AZ
    2003 Prius
    Or a 12v motorcycle battery. Or a garden tractor battery from Walmart. Or a battery out of a mobility scooter. Or battery out of a computer UPS box. My Prius has a UPS box battery, it works fine.
  9. fuzzy1
    10,332
    It is already expired.
  10. CR94
    CR94 Senior Member
    2,658
    1,147
    Northwestern S.C.
    Same here. (General purpose AGM used for UPSs, scooters, and many other applications, including Prii. $70 new)
  11. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    You can just buy a lithium starter battery that has the charge controller built in. No need to hack anything.
  12. TMR-JWAP
    6,404
    6,080
    Columbia, SC
    No, no, NOOOOO. This experiment MUST happen. Maybe instead of 2 lantern batteries, I'll go with 9 D cells. Just thought the lantern batteries would last longer. Hmmm, idk. I'll come up with some kind of MacGyver **** to try. How many potatoes would it take to power up the electronics in a prius?
    2k1Toaster likes this.
  13. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    A petrol-potato hybrid. Lets replace the entire HV pack with potatoes!
  14. Prodigyplace
    12,366
    11,661
    Central Virginia
    ...until somebody comes along and MASHES your battery. :cry:
    douglasjre and kc410 like this.
  15. douglasjre
    douglasjre Senior Member
    2,062
    691
    Null, NL
    Mashed potatoes, dragged through the electric garden
    Prodigyplace likes this.
  16. ETC(SS)
    6,841
    @TMR-JWAP did you ever try this with the lantern batteries?
    I was going to try it myself, but i seem to have run out of work-car Priuses to try it out on.
    If I ever find a G3 in good condition that coded from a head gasket........:D
  17. TMR-JWAP
    6,404
    6,080
    Columbia, SC
    No. Once I remembered that the brake actuator cycles, I figured there was no way the lantern battery trick would be able to supply that much current and maintain any workable voltage.
