Making a M3U playlist on thumb drive
Discussion in 'Prius c Audio and Electronics' started by Chris92057, Sep 4, 2015.
  1. Chris92057
    Chris92057 Junior Member
    49
    Jacksonville Fl
    As a recovering on-air host (hey, radio jobs are hard to keep!), I enjoy making playlists of my library of music. I have three thumb drives of music that I have in my personal library.
    Noodling around the internets, I wanted a playlist that would work on the 2013 Prius C III. The standard I found is the M3U.
    I found the perfect list maker: It is called M3U Dropper. This free program does not install on your Windows PC.
    I insert the thumb drive on my PC and open the program -- then drag and drop, rearrange, and save as a .M3U file on the thumb drive. That's important: save the playlist on the thumb drive!
    I've made a playlist almost seven hours in length. Google search the name (M3u Dropper). Best wishes and turn it up to 11.
    Once inserted to the port, use the 'browse' feature and you should find the playlist. Name your lists differently.
    Cheers!
