Max Sidewall Pressure...
Discussion in 'Gen 3 Prius Fuel Economy' started by spork, Dec 12, 2010.
  1. spork
    spork No Spoon - I Drive a Spork!
    KY
    Sorry if it's been covered, but... how do you find the max sidewall tire pressure? Is it the same as the max pressure listed on the tire? I want to inflate my tires but I want to get the best results I can.
  2. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    They are two names for the same thing. It has been covered in many threads. You will be able to find them with the search feature.
  3. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    Yes, the Maximum pressure listed on the tire itself is commonly used as a guide to inflate Prius tires. Toyota's reccomendation on the driver's door jam, yeilds a smoother ride, but less tire life and lower mileage. It is common to inflate the rears two pounds less than the fronts. (I use 2 pounds less than the max in front and 4 pounds less than the max in back)
  4. spork
    KY
    That was exactly my plan...
  5. Bob64
    1,540
    93
    Virginia
    If your roads suck, max sidewall pressure will let you "feel" more of the bumps (all of em).
  6. Den49
    Den49 Member
    498
    272
    Maryland
    "Max. sidewall pressure" will also decrease traction and increase stopping distance, tradeoffs which IMHO are not worth the fractional increase in MPG.
  7. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    You ran tests on a Prius? Can we see them?
  8. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    My 2006 had better traction on wet pavement at max sidewall pressure. I never measured stopping distance.
    The only time my 2010 was intentionally below max sidewall was on the first trip home from the dealer.
    The attached file is a professional's point of view.
    5 people like this.
  9. fuzzy1
    10,479
    Several NASA and aviation sources, as pointed to in earlier posting on this subject, show that higher pressures improve hydroplaning resistance. In my climate, this is important.
  10. spork
    KY
    Regardless of opinions, my cold tire pressure was 30 psi all the way around today. Gotta love winter!!!
  11. spork
    KY
    Don't think your anecdotal opinion supports the more studied evidence, but as is the way I am, you're certainly welcome to opine and to fill your tires to any pressure you'd like!
    And... I drive 140 miles minimum daily. Fractional increases make a difference. :)
  12. Den49
    Den49 Member
    498
    272
    Maryland
    Yes, but only with regard to underinflated, not properly inflated, tires. Also, isn't difficult to fly and hydroplane at the same time? :confused:
  13. Den49
    Den49 Member
    498
    272
    Maryland
    Good article from the police perspective, but he is speaking of a tactically loaded police package Crown Vic. Having owned two Crown Vics with performance and handling packages, I can tell you that the Prius is NO Crown Vic.
  14. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Aircraft have devices called brakes at the wheels. They aren't effective when hydroplaning. [​IMG] They are important enough that ABS was used on aircraft before cars. When no longer flying, aircraft are also steered by the wheels and depend on the wheels for directional stability.
  15. spork
    KY
    Den, you apparently missed the points of the articles and the physics. And excuse me... NASA is made up of engineers and physicists, and many of them are deeply involved in surface engineering - not flying. Okay, business people, too, but they don't have a pony in the show of making life more dangerous. Sorry, but your point of view (and what was mine prior to sincere and critically analyzed information) doesn't hold true. At all.
    Still, I'm glad you responded.
  16. Den49
    Den49 Member
    498
    272
    Maryland
    Do you have any "studied evidence" that you can reference or share?
    There is another thread, MPG difference between recommended and max tire pressures?, that is asking for data on mpg differences.
    http://priuschat.com/forums/gen-iii...e-between-recommended-max-tire-pressures.html
  17. Den49
    Den49 Member
    498
    272
    Maryland
    What "articles and physics" are you refering to? I would be happy to be educated and converted to your opinion if you can reference or post authoritative and convincing documentation. BTW I am very familiar with the NASA folks, having been at Goddard on a number of occassions and knowing people who do good work there.
  18. fuzzy1
    10,479
    If that is true, then the door placard psi recommendation on my old Honda (before the Explorer rollover problem surfaced) was simply wrong. Hydroplaning in that car is what lead me to this issue.
    The hydroplaning resistance formula in the mentioned articles has no cap at any 'properly inflated' pressure.
    Use the PriusChat 'Search' function. This issue repeats several times per year.
  19. spork
    KY
    So have I, and so do I. For all I know, we may have met. :) But if you notice, I didn't bring NASA into it - that was another response.
    As I said, you're welcome to disagree... well, except about whether I brought up NASA. :D
    Okay, so I referenced them, but I didn't bring them up! :D :D :D And I bet they wouldn't all agree about tire pressure, either, in any direction!
  20. Den49
    Den49 Member
    498
    272
    Maryland
    Its not clear to me what you are trying to say in your first statement, but I happened to receive this newsletter Best Tires for Bad Weather - December 2010 - Eriesense.com from Erie Insurance today which says:
    "Find the tire pressure number for your vehicle on the driver’s side door or in the glove compartment. It’s not the number on the tire sidewall. That’s the “maximum permissible” for that tire. The vehicle manufacturer determines the correct tire pressure for your vehicle. Why? Because proper pressure is based on vehicle design load and tire size."
    Also, what "mentioned articles"? You want me to search to make your point? Please!!!
    Everything I read and hear from reputable and authoritative sources says to follow and use the auto manufacturer's recommended tire pressures, not the maximum pressure on the tire sidewall, as confirmed again in the above Erie Insurance article. I need something more definitive and authoritative to the contrary before I can change my opinion on this one.
