Mechanical question: does Prius have distribution?
Discussion in 'Gen 2 Prius Technical Discussion' started by mandrei83, Jun 7, 2009.
  1. mandrei83
    mandrei83 Member
    139
    32
    Stockholm, Sweden
    Mechanical question: does Prius gas engine have belt/chain timing?
    Hello,
    Since I'm a newbie Prius owner and I don't know much about my car, I would like to ask you if Toyota Prius gas engine has chain or belt timing..:confused:
    Also, on which mileage needs to be changed? At normal vehicles, the belt timing needs to be changed at 60.000Km, or the other on chain, at about 90 or 12.000km.
    BR,
    Andrei
  2. jdenenberg
    jdenenberg EE Professor
    3,910
    1,908
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Re: Mechanical question: does Prius gas engine have belt/chain distribution?
    Andrei,
    The issue is usually about timing belts or chains and whether the engine is an "interfering engine" (will the valves hit the pistons if the timing belt breaks). In a non-interfering engine a broken timing belt only stops the car (no direct damage).
    The Prius has a timing chain that typically will last the life of the engine. It will start to make noise to warn you before it fails so we can ignore this maintenance issue in a Prius.
    JeffD
  3. F8L
    19,011
    4,082
    50
    Grass Valley, CA.
    Neither of those Andrei. It has a distributorless ignition system.
    This is one less part you do not have to replace on a Prius.
    2 people like this.
  4. F8L
    19,011
    4,082
    50
    Grass Valley, CA.
    Thanks jden,
    I hit submit before I could write in the part about the timing chain and not needing to be serviced. :)
  5. tochatihu
    tochatihu Senior Member
    9,452
    3,654
    Kunming Yunnan China
    2001 Prius
    I guess the crankshaft position sensor provides the approximate timing of each cylinder spark, then the computer decides the detailed timing (and duration??) and sends a 12 v pulse to the ignitor in question. Ignitor does the rest.
    I had an older Mercedes in which the crank-driven distributor was a chronic low-level oil leak. That can be a small issue atop distributor maintenance already mentioned.
    The computer-cleverness of modern vehicles really has reduced routine maint, no doubt about it.
  6. F8L
    19,011
    4,082
    50
    Grass Valley, CA.
    You have it pretty much down. My old LS1-based GM cars worked in much the same way. In the ECU are fuel and timing maps. The maps contain "Excel-like" cells with rpm and load on each axis and within the cells are the exact timing numbers that with be applied when a specific RPM and load is reached. This is very simplified but it gives the basic idea.
    Here is a quick video that describes
    . It is pretty bad/old lol
    2 people like this.
  7. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    To the OP, if you're talking about how the camshaft works, it has a timing chain.
    The Prius timing chain is considered lifetime, there is no set replacement schedule
  8. mandrei83
    mandrei83 Member
    139
    32
    Stockholm, Sweden
    Ok then, thanks to all of you for reply..
    Sorry for my formulation (distribution), but it should be "timing" the one that I was talking about.:)
    Topic can be closed, my question was clarified..:rockon:
