Mercedes Diesel Hybrid
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by bwilson4web, Oct 22, 2010.
  1. bwilson4web
    15,939
    Browser Warning
    Interesting approach.
    Because the motor is clutched, it could work but there is nothing in the article about the battery capacity in kWhr. But I get the impression this is more test mule than an announced product.
  2. clett
    clett New Member
    537
    Scotland
    "all of the hybrid technology, including the high-voltage battery, is housed in the engine compartment"
    Interesting, should save some space.
  3. austingreen
    austingreen Senior Member
    13,628
    4,172
    Austin, TX, USA
    Mercedes and BMW will be putting their hybrid system across their lines in the next 5 years. The battery is likely the same 0.9kwh LI battery they used in their s400. In that application the hybrid components only added 110lbs. Because its lithium it probably has about the same usable capacity as our prius battery, but the car is much bigger. In the bmw activehybrid 5 they are using a bigger 30kw motor, and could be using a larger capacity battery.
