Metal on metal grinding noise at high speed above 75mph???
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by deunan, Jan 20, 2012.
  1. deunan
    deunan Junior Member
    27
    PDX
    I commute 180 miles a day, 6 days a week. I noticed metal on metal grinding noise(more noticeable) at high speed above 75mph especially on asphalt road. I'm sure noise is there at low speed but not enough to notice.
    My car has 50,000 miles.
    Any suggestion? Tires? Electric motor?
    Should I worry?
    Thanks
    Mike.
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    What sort of grinding noise? Something like suspension noise, or more mechanical?
    You should hear more wind and road noise at higher speed, but that's it.
    Tom
  3. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Wheel bearings? Does the car still drive solid or do you feeling it drifting?
    Assumed you already looked under the vehicle for anything hanging down.
    I would bring it in.
  4. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Grinding? A metal grinding and you're still driving it?
    You sure it's not the plastic cover under the engine/bottom of the car? If you hit a flood or a big puddle or bottomed the car out it might have come loose.
  5. HyperFX
    HyperFX NIMFY (not in my front yard)
    81
    35
    30
    New Jersey
    Sometimes it may be the brakes and rotors grinding against each other due to running over a curb, misalignment or other possible damage.
  6. deunan
    27
    PDX
    when I go over big speed bumps, I do hear shock noise, rubbing squeak. I did bottom out my car on a big dip when i was entering a business drive way but there was nothing hanging. It sounds like mechanical maybe from electrical motor whine? transmission whine??? tires shouldn't make metal on metal whine noise, i think. I can hear clear whine noise on asphalt road-metal whine is greater than road nosie :( . I'll do another walk around tomorrow.
    car still gets around 45mph going 75+mph.
  7. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    Maybe when you're stationary the plastic cover hangs correctly but when you get upto speed it is blown down onto the road making the noise.
    Alternatively, if you hit the bottom of the car hard you might have broken something? Make sure you haven't cracked the sump or the transmission and that the fluid hasn't leaked out!
  8. El Dobro
    El Dobro A Member
    7,071
    3,258
    At the least, you should put the car up on a lift or ramps and look around.
