MFD changed for no reason
Discussion in 'Gen 2 Prius Technical Discussion' started by Wa1hog, Oct 8, 2008.
  1. Wa1hog
    Wa1hog Old Blind Hippie
    95
    South West New Hampshire
    I was driving home one night and noticed that the MFD changed with no user input.
    It was on the consumption page. At the top of the display it normal reads CONSUMPTION on the top left and outside temp on the top right.
    For no reason the CONSUMPION word disappeared and the outside Temp moved to the top middle of the display. This lasted for about 3 to 5 seconds then went back to the normal display.
    Anyone else notice this?
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,079
    Northern Michigan
    What was the outside temperature? Was it 37 degrees by any chance?
    The Prius gives a freeze warning when the outside temperature drops to 37. It's a hold-over from the snowflake on the earlier Prius.
    Tom
  3. Wa1hog
    95
    You know... Yes I would say it was 37 outside. But why only a few seconds and no audio warning.. Matbe there was an audio warning but didnt hear it. Ill keep an eye out for another 37 degree night.
    Thanks
  4. qbee42
    18,058
    3,079
    Northern Michigan
    Because that's the way it works. Why? Who knows. Why 37 degrees? No one knows that either, unless we get deep inside the engineering minds at Toyota.
    Tom
  5. Patrick Wong
    18,210
    6,510
    Maybe because when it is 37 degrees F a couple of feet above the road (where the outside temp sensor is located), then the road itself will be close to 32 degrees F?
  6. Wa1hog
    95
    I had a outboard temp gauge once that beeped when the temp got to 39 degrees.
    Probably because some roads and bridges will freeze when the temp 4 feet above ground level gets to 39 degrees.
  7. Ogo
    Ogo Prius Owner since 2008
    220
    44
    Ilirska Bistrica, Slovenia
    That is around 3 degrees Celsius. At least all Toyotas sold in Europe have a freeze warning below this temperature. So for me, this makes sense for Prius, too. :)
    Ogo
  8. qbee42
    18,058
    3,079
    Northern Michigan
    Exactly. It's just set a few degrees above freezing. How they picked the exact offset is a mystery.
    Tom
  9. Sufferin' Prius Envy
    Sufferin' Prius Envy Platinum Member
    3,998
    37 degrees, because as temperatures rise, all ice does not disappear instantly just because the air has risen above 32.
    If you get in your car for your morning commute and the air temperature is 33 degrees, wouldn't you like that warning? 37 is a safety cutoff.
    I love my 'snowflake.' :wub:
    I consider it my 'going skiing happy-light.' :biggrin1:
    That's when I see it the most.
  10. kevinwhite
    kevinwhite Active Member
    333
    200
    Los Gatos Ca
  11. qbee42
    18,058
    3,079
    Northern Michigan
    It doesn't work that way with the new Prius (post snowflake). You get the warning when the temperature drops to 37. You can drive all day at 33 and not get a warning.
    Tom
  12. Wa1hog
    95
    I remember way back in the stone age in science class. We had to figure how many calories was used to melt ice at 32 degrees.
  13. patsparks
    10,664
    567
    Adelaide South Australia
    I recall this experiment, except we used joules.
    I believe the 37 degrees C isn't a random temperature but is a danger zone temperature for black ice. I'm also guessing Toyota responded to the whining babies who complained about the light being on all winter so they dropped it from later models but there is still an MFD response. Search the snowflake if you want to read some whiny baby posts.
  14. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    No, sorry. I was looking out the window at the time. :D
  15. qbee42
    18,058
    3,079
    Northern Michigan
    Latent heat of fusion. It's 60 calories per gram.
    Tom
  16. Sufferin' Prius Envy
    3,998
    37 degrees C ???
    Mannnnn that's some real nasty black ice if it can survive in 98 degrees F. ;)
    Or do thermometers work backwards when they are upside-down there in the Southern Hemisphere? :p
  17. Celtic Blue
    Celtic Blue New Member
    2,224
    139
    Midwest
    Keep in mind that bridges and overpasses can easily radiate heat away at night and be considerably colder than the surrounding air. With the temperature close to freezing, a little water vapor can condense and freeze on the surface of the road. 37 degrees F seems a reasonable point for a warning.
    Outer space (and the upper atmosphere) is very cold...so on clear nights there is considerable radiant heat transfer from objects exposed to the sky, and they grow colder than the surrounding air. Dew and frost result. The driving force for this radiant transfer is the difference between each of the absolute temperatures raised to the 4th power if memory serves.
    There is also the condition where the road is already cold and the air temperature warms.
  18. archae86
    archae86 Member
    153
    24
    Albuquerque, NM
    My 1987 BMW gave me a visual and audio warning at some temperature near 36 F. My 2002 Audi A4 does so, but at a higher temperature (maybe 41F).
    As the old sign "bridge freezes before road surface" reminds us, radiation cooling can make a portion of the road cold enough to condense moisture and make ice while the air temperature is still well above freezing.
    Interestingly enough, the Audi turns OFF the continuing visual indicator (it looks like a snowflake) when it gets cold enough (low 20s F, if I recall). I don't know whether the thinking is that it is less slippery down there, or just that your are unlikely to be unaware.
  19. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    I kinda like the snowflake. Not that I've seen it yet this year, but it makes more sense to have a continuous, unobtrusive warning than a quick flash.
  20. EZW1
    EZW1 Active Member
    722
    81
    Phoenix, AZ
    2016 Prius v wagon
    Four Touring
    37 degrees is the temperature universally decided upon where the production of ice on the vehicle or road could occur, depending on relative humidity and speed of the vehicle. Most review mirrors that have the integrated outside temp display will begin to flash a caution to the driver at 37 degrees for this purpose...
