MG1 and MG2 made to handle daily EV driving?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by markabele, Oct 1, 2013.
  1. markabele
    5,084
    1,782
    Nebraska
    It's just bugging me in the back of my mind....
    Weren't the electric motors in our PiP's made to go in a much lighter duty application (regular hybrid use)?
    I'm just wondering if over time they will wear or break down faster since they might not be able to handle daily heavy full EV use.
    Thoughts?
  2. Michael33
    Michael33 Member
    372
    62
    Upstate NY
    2013 Prius Plug-in
    I'd direct this question to the people responsible for the existence of the PIP. No, not Toyota. I mean the folks who made their own Plug-In Priuses, using add-on battery packs. That began about a decade ago, so they should have real world info on motor wear. My guess is that because Toyota used to routinely over-engineer components for longevity, and because the Prius predates the 2006 takeover of the company by Junior, the motors were probably (even the latest generation) designed to handle much more power than the battery pack could provide at the time...
  3. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    This thought crossed my mind as well.
    The arguments I gave myself (for peace of mind) were:
    I do not think PIP MG1 is working harder or more frequent than the regular Prius.
    Max power draw from battery is 27 kW for regular Prius and about 35-38 kW for PIP, both are considerably below the 60 kW rating of the MG2, so it is working under-loaded.
    Electric motors are working for years with no issue even when fully loaded.
  4. Prius 2007 user
    Prius 2007 user Junior Member
    It's electric motors, and those are known to be able to resist any amount of abuse. An uncle of mine was in charge of a city trolleybus fleet many years ago, they all had more than 600,000 miles on the clock and were still going strong, and that was 1950s technology. He often told me he was dreaming of the day when the technology could be applied to cars. Well, he's long dead now, but his dream has come true ! So, just use it, abuse it and don't worry about a thing.
  5. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,342
    Wilmington, NC
    You ask a good question because part of an electric motor design can be based on duty cycle, the ON time versus the OFF time. Motors designed for other than continuous duty can have less iron and copper since they are dependent on the OFF time for cooling. The regular Prius MG2 normally only sees high currents for brief periods when stopping and starting or for limited EV use. With the PiP the EV can be for a much longer period of time.
    You would need to know Toyota's design criteria for these motors. Without this criteria, you can monitor MG1 and MG2 temperature. I know from the 2010 Repair Manual the upper temperature range of the motors are quite high.
    I would think monitoring these motor temperatures should help answer this question for you.
  6. bisco
    50,813
    i wouldn't be surprised if they eventually failed.
  7. Jeff N
    Jeff N The answer is 0042
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    Of course only time will tell but the motors in a Prius are operating all the time when the gas engine is running as well and, as someone noted, are operating well under the design peak capacity in EV mode due to limitations in the power output of the plugin's battery pack. I'm sure Toyota considered all of this carefully. I wouldn't worry about it any more than any other major powertrain component. Do you worry about the water pump as you are driving down the freeway?
    SJ PiP and CaliforniaBear like this.
  8. jdcollins5
    5,131
    1,342
    Wilmington, NC
    For a temperature reference I went back and checked the 2010 Repair Manual.
    MG1 Temp High - 334F (168C)
    MG2 Temp High - 324F (162C)
  9. fuzzy1
    10,332
    This is true only of those motors well designed for their applications.
  10. El Dobro
    El Dobro A Member
    7,071
    3,258
  11. Michael33
    Michael33 Member
    372
    62
    Upstate NY
    2013 Prius Plug-in
    Yes, and once again, that's because of the people who ignored Toyota's naysaying and adapted their Priuses to become plug-ins.
