Misfire after replacing fuel injectors
Discussion in 'Gen 3 Prius Technical Discussion' started by Mike_priusfamily, Feb 27, 2025.
  1. Mike_priusfamily
    Mike_priusfamily New Member
    Richmond-Katy
    So, I replace the fuel injectors on my 2010 Prius with 330k miles on it. After doing so (and taking care of the o-ring problems), I had a misfire on cylinder 3 with awful vibrations.
    I found that one of the pins in the electrical connection was bent. I straightened that and all is well.
    So, if you've got this problem, check your connections.
    Brian1954 likes this.
