Mobil 1 - What's recommended
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ServoScanMan, May 11, 2006.
  1. ServoScanMan
    ServoScanMan Member
    262
    Lorena, TX
    I have not changed the oil yet on my new Prius. What is the recommended weight? 10W-30? Does anyone know how much oil (with a filter change) the ICE will hold? Thanks!
  2. benighted
    benighted New Member
    530
    Westport, WA
    it takes 5W-30 and 3 quarts of it
  3. sdsteve
    sdsteve New Member
    88
    <div class='quotetop'>QUOTE(ServoScanMan @ May 11 2006, 07:05 PM) [snapback]253902[/snapback]</div>
    I think the manual says 5W-30 and 3.9 qts. (nice round number). Have to be careful not to overfil with the complete last quart.
    Steve
    <div class='quotetop'>QUOTE(benighted @ May 11 2006, 07:12 PM) [snapback]253904[/snapback]</div>
    Is it only 3 and not 3.9??
  4. benighted
    530
    Westport, WA
    There have been many posts with complaints about the dealerships overfilling the oil, the 3.9 number in the manual might have something to do with it.
    When I change my oil I pour in 3 quarts and add more if it needs it, but it never takes more than 3.5 quarts.
  5. aaf709
    3,862
    2022 Prius Prime
    <div class='quotetop'>QUOTE(benighted @ May 11 2006, 08:32 PM) [snapback]253924[/snapback]</div>
    If you take it to a dealer for changing, some will allow you to bring in your own oil. Give them 3 quarts and tell them you'll put in the rest. If you give them 4 quarts, they'll be inclined to put all in.
  6. kDB
    kDB New Member
    241
    Fenton, MO
    3.9 is a misprint. when filling a dry engine it takes 3.9. under normal oil changes, you will never get a dry engine, there is usually about 1/2-3/4 of a quart still in the engine. i would suggest 3 quarts and check the level. 3.25 seems to work well for me though.
  7. bsd43
    bsd43 Member
    130
    San Francisco Bay Area
    <div class='quotetop'>QUOTE(kDB @ May 12 2006, 04:35 AM) [snapback]254014[/snapback]</div>
    You sure about that? My change took just short of 4 quarts.
    I just don't see how putting a quart less could raise fuel economy, in any case, as some has suggested in other threads.
  8. Charles Suitt
    Charles Suitt Senior Member
    1,637
    17
    Dallas TX
    :eek: ServoScanMan
    Your Owner'a Manual has extensive information regarding ICE lubrication. Try Section 8-2, page 283 and 312 in the back section.
  9. hting1688
    hting1688 New Member
    My dealer refused to do it with three bottoles of Mobil-1. I had to run to a auto shop to get an extra one.
  10. ServoScanMan
    ServoScanMan Member
    262
    Lorena, TX
    <div class='quotetop'>QUOTE(hting1688 @ May 12 2006, 07:09 PM) [snapback]254435[/snapback]</div>
    Did you actually 'run' to the auto shop? B)
    Thank you all for your replies. I think (when it's time) I will drain oil, change the filter, fill with 3 quarts of Mobil 1 and check the level.
  11. furkidsnprius
    furkidsnprius New Member
    63
    Massachusetts
    I just received a mailing of a Toyota technical service bulletin which states that I should use 0W-20 ILSAC GF-4 motor oil in my Prius. This is a synthetic oil and a rather pricey one at that, about $45. Has anyone out there used synthetic oil? It is supposed to increase gas mileage and cold starting performance.
  12. wb9tyj
    wb9tyj 2017 Prius Prime Advanced
    389
    95
    Indiana and Nevada
    i have used 3.5 quart of mobil1 for 2 years now...changed mine myself from day 1...i have a 2004 pkg #9
  13. benighted
    530
    Westport, WA
    <div class='quotetop'>QUOTE(Marie @ May 12 2006, 06:57 PM) [snapback]254490[/snapback]</div>
    I imagine it doesn't get too warm in New England, thats probably why they sent the bulletin to you. I'm going to keep running Royal Purple 5W-30 in mine as it doesn't get too far below freezing in the winter time.
    On my last oil change the parts shop gave me 3 quarts of Royal Purple "Racing 11"(similar to 5W-20) and 1 quart of RP 5W-30. I didn't notice until I pulled the oil filter off but figured that the Prius could benefit from a lighter oil so I used the 5W-30 and filled it the rest of the way with the "Racing 11"
  14. richard schumacher
    7,664
    1,042
    United States
    <div class='quotetop'>QUOTE(Marie @ May 12 2006, 08:57 PM) [snapback]254490[/snapback]</div>
    Are you certain this was from Toyota and not from some car dealer or service shop?
  15. furkidsnprius
    63
    Massachusetts
    <div class='quotetop'>QUOTE(richard schumacher @ May 12 2006, 10:35 PM) [snapback]254553[/snapback]</div>
    Yes I am pretty sure as it came from the Toyota dealer where I purchased my new Prius. It is TSB EG018-06, looks official was issued March 29, 2006. The box which says TSB update notice states"The information contained in this TSB supercedes TSB No. EG001-06. TSB No. EG001-06 is now obsolete and should be discarded." There is another box with this note "For Prius vehicles, refer to TSB No. EG050-04, Engine Oil Specifications." Then further down it reads Applicable Vehicles 2006-2007 model year Toyota and Scion vehicles. Is there somewhere online to look up TSB's? I am not convinced this bulletin refers to my prius but the dealership says it does. What do ya'll think?
  16. Tempus
    Tempus Senior Member
    1,690
    Washington DC
    <div class='quotetop'>QUOTE(Marie @ May 13 2006, 08:01 AM) [snapback]254671[/snapback]</div>
    Here's where we talked about it when the TSB first came out.
    http://priuschat.com/index.php?showtopic=18413
    Yes, the TSB specifically excludes the Prius.
  17. furkidsnprius
    63
    Massachusetts
    Thanks for the reply. I read the thread. Seems like I can use whichever 5W-20 or 0W-20. In my colder region of the country I might be better off with the 0W-20.
    Marie
