Moisture in Taillights
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by mrb1, Dec 28, 2012.
  1. mrb1
    mrb1 Junior Member
    17
    Earth
    I have a 2012 Prius 3 and just noticed yesterday that I have some condensation on the inside of my Taillights. It's been raining and cold around here lately but I park my car in the garage. Has anyone have the same problem?
    You could see it in the pics below.
  2. F8L
    19,011
    4,082
    50
    Grass Valley, CA.
    I have that too. It's not bad enough that I was planning on doing anything about it. When I take the rear panels off I will look to see if they can be sealed better but I don't think it's a big deal.
  3. mrb1
    mrb1 Junior Member
    17
    Earth
    You are right it's not that bad at this point. Just don't want it to get worse over time. I was thinking of bringing it in to the dealer to see if they could fix or replace it since its still under warranty.
  4. katiesdad7
    katiesdad7 Member
    172
    25
    Stuart, FL
    Warranty item for sure.
  5. zhutton
    zhutton Junior Member
    85
    Staffordshire, UK
    Happened to mine, I just left the parking lights on for best part of 2 hours and it appeared to go, led so I wasn't expecting much heat but coincidentally it went, if it starts becoming a problem then a moan at the dealer should suffice
  6. rrg
    rrg Active Member
    458
    120
    East coast - NJ
    Check around the sockets and make sure that area does not have any loose sockets.
    If they are locked, then the lens has an opening allowing moisture in.
    Just wondering, did you get moisture in both sides at the same time? Was the car on an incline outside?
    Dealer visit next.
  7. mrb1
    mrb1 Junior Member
    17
    Earth
    I think I will take it in to the dealer. Figured I paid good money for this car why not use the warranty.
  8. mrb1
    mrb1 Junior Member
    17
    Earth
    That's the weird part, moisture was in both taillights. I park my car in the garage at night with no incline so it wasn't sitting outside in the cold at all.
  9. Rebound
    Rebound Senior Member
    3,970
    2,623
    Portland, OR
    I noticed this on mine. It didn't occur to me that it was a problem I should have repaired.
  10. mrb1
    mrb1 Junior Member
    17
    Earth
    It's not a big deal at the moment but I don't want to find out it will be a problem after my warranty expires.
  11. Rebound
    3,970
    2,623
    Portland, OR
    By all means, please keep us updated after your dealer visit. That would be very appreciated. I'll definitely take mine in if they so something about yours. Thanks!
  12. mrb1
    mrb1 Junior Member
    17
    Earth
    Definitely will keep everyone posted. It will be a couple of weeks before I will be able to make it to the dealership.
  13. mrb1
    mrb1 Junior Member
    17
    Earth
    Update....So I went to the dealership today and they said Toyota will most likely not cover this issue unless there were actual droplets of water inside the Taillights. They said they will submit the work order anyways and see if Toyota will approve the repair work. I should hear back in several days.
  14. zhutton
    85
    Staffordshire, UK
    I'm sure the problem could be rectified to their specifications if required?
  15. mrb1
    mrb1 Junior Member
    17
    Earth
    The only experience I had with warranty was the one claim with Infiniti and I had to fight them to cover the issue. I hope Toyota will not be the same.
    My two other cars did not get moisture in the taillights that same day so I don't think it's normal but I'm sure they will say its normal somehow.
  16. zhutton
    85
    Staffordshire, UK
    my window tint bubbled when i had my car and i went through 3 months of arguing to get them to re apply the tint..... dealers in general i think :/
  17. mrb1
    mrb1 Junior Member
    17
    Earth
    Got a call from the dealership and they said Toyota will not cover the repairs because it is normal for the Taillights to fog up inside because they are vented. It's weird that my other car's lights did not fog up that day if it's normal.
  18. rrg
    rrg Active Member
    458
    120
    East coast - NJ
    I don't think it's normal.
    Here's an idea I found. Open all the light sockets and use petrolium jelly or dielectric grease to lub or seal the gasket around the lights sockets. Be sure to only touch the gasket material with the lub.
    Here's another fix to keep water out of the tail lights.
    my2cents.
  19. mrb1
    mrb1 Junior Member
    17
    Earth
    I'm going to give Toyota Corp a call and see if I could change their mind and replace it. If not then I will give the DYI a try.
  20. Willem
    Willem Junior Member
    51
    For what it's worth, my 2010 Prius has the same issue. A visit to my local dealer resulted in them telling me it was a) not unusual for a Toyota and b) not covered under the warranty.
    Since I have had several other minor annoyances covered by warranty, I can only assume that the dealer is being up-front with me. After all, don't dealers have a financial incentive to fix warranty issues because they get compensated by the manufacturer?
