MPG calculation?
Discussion in 'Gen 2 Prius Technical Discussion' started by bcrill, Aug 18, 2006.
  1. bcrill
    bcrill Junior Member
    Hi folks,
    I'm wondering - does anyone know how the Prius estimates the MPG that appears in real-time on the display?
    I can't imagine that it would literally divide the distance driven by the fuel flowing to the ICE during the ~ 1 second update time - seems like you'd get a large error dividing two small numbers.
    Thanks!
  2. kevinwhite
    kevinwhite Active Member
    331
    199
    Los Gatos Ca
    <div class='quotetop'>QUOTE(bcrill @ Aug 18 2006, 02:02 PM) [snapback]305550[/snapback]</div>
    I'm sure that's what it does - there is no other information available.
    That probably gives a lower limit on the update period or the quantization in distance or volume would be too great.
    The five minute bars use information obtained over a longer period so the quantization error will be smaller.
    kevin
  3. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    vehicle speed and distance
    injector duration and frequency
    *assumes* nominal fuel pressure behind it
    _H*
