MPG decline when off or in idle
Discussion in 'Gen 2 Prius Technical Discussion' started by Dr Ed, Apr 10, 2008.
  1. Dr Ed
    Dr Ed New Member
    188
    I noticed when I park and shut down for the night then return and start up the next morning, the MPG has decreased during the night. And after I start the car and let in idle in park for a minute or so the MPG will continue to tick down, as much as about 10 MPG. I have not noticed it before this week; not that it might not have been happening without my observing. This morning for example, on start up the MPG on the screen was 40. When I parked last night it was 47. While it idled in park a minute it intermittently went down to 36.5. Anyone know what’s up with that?
  2. miscrms
    miscrms Plug Envious Member
    2,079
    526
    Phoenix, AZ
    Not sure about it moving overnight. If you have recently reset (manually or by filling up) the MPGs will move around very easily. When the car is warming up but not moving, the ICE is burning gas but no distance is being covered so you're getting 0mpg. That will be pretty detrimental to your average MPGs. The same thing happens when I leave the wife and kid in the car with the AC on, each time the battery gets low the ICE kicks on to recharge. Its pretty surprising how quick that can ruin your average MPG. In general its better to just shut the car off, or open all the windows and turn all the accessories off when just sitting with the car on to minimize this when possible/convenient. As far as the warmup cycle goes you are better off just waiting to start until you are ready to go. If the ICE is going to run anyway, you might as well be moving. I believe you will also get through the warmup cycle faster and improve your overall MPGs if the ICE has some load on it, rather than just idling.
    Rob
  3. richard schumacher
    7,664
    1,046
    United States
    Yes: idling wastes gas. Don't do it. The fastest way to warm up a Prius is the same as any other car. Drive it, gently for the first minute or two.
  4. Winston
    Winston Member
    614
    SF Bay Area, California
    Also, if you leave your climate control on, it will keep the engine running to help warm up the inside of your car. Whereas normally, after warm up, the engine will turn off at stop signs/lights, if you have your climate control on, the engine will keep running at stop lights/signs.
    Unless it is really cold in my car, I always keep the climate control off until I get on the highway.
  5. bwilson4web
    16,215
    In the case of the NHW11, I like to use a 25 mph average speed for the first 1.5 miles at temperatures of 60F or warmer. As often as possible, I slip into "N" for the glide since this further reduces fuel consumption even when waiting at a light or stop sign. But after 1.5 miles, you'll be in S3 and if you can come to a stop and let the ICE autostop, you'll be in S4 and full hybrid mode.
  6. Dr Ed
    Dr Ed New Member
    188
    I never let it idle until I noticed the weird drop in mpg between parking at night and starting in a.m. I looked at mpg when I parked, then looked when I started up the next morning. Immediately I saw a negative mpg difference from the night before. And while watching for about a minute as it idled during my observation, it continued to drop a total of about 10 mpg before I ever put it in drive. I did not know you could lose mpg as the car idled in park or when you first start it up in the morning. Thanks for the feedback folks.
