MPG indicators and calculation
Discussion in 'Gen 3 Prius Main Forum' started by nola_Prius, Aug 9, 2009.
  1. nola_Prius
    nola_Prius New Member
    405
    62
    New Orleans
    Let me get this right... if I have the car running, but in park, the MPG indicator will still deduct that from the fuel efficiency? Why is this?? Is this most likely the cause for the difference in hand-calculated MPG vs. what the car says the MPG is?
    Also, aside from Trip A and Trip B MPG results, are there any other running "lifetime of the car" MPG indicators?
  2. fuzzy1
    10,332
    If the engine is running, the fuel consumed is increasing. But if the transmission is in Park, the miles run is not increasing. Simple math, the MPG since the meter was reset is decreasing.
  3. nola_Prius
    405
    62
    New Orleans
    Yeah, but if you aren't moving, no "M" in MPG is being added.
  4. fuzzy1
    10,332
    Exactly. When M is constant, but G increases, (M/G) must decrease.
    The fuel consumed while stationary is not free. It has to be counted too. Otherwise, non-hybrids that always waste fuel while idling, even when already warm, could exclude that wastage and claim higher MPGs.
  5. nola_Prius
    405
    62
    New Orleans
    I understand that simple concept.
    My point is that if I left my car running from a full tank, and after however long, the tank emptied... does that mean that my Prius gets 0 MPG???
    No, of course it doesn't. That is why the MPG indicator should not be changed if I am sitting at a standstill.... in my opinion.
  6. jburns
    jburns Senior Senior Member
    829
    111
    Archdale, NC
    But your Prius did get zero miles per gallon for that tank. No way around it. You put 11.9 gallons in, burned it and never moved. Zero MPG. On the plus side you probably got a heck of a lot of BTUs.;)
  7. nola_Prius
    405
    62
    New Orleans
    I see what you're sayin, but it's kinda lame because those gallons weren't spent gaining distance with the car. They shouldn't be figured into MPG, because no miles were gained.
    It makes sense, but it's stupid and I don't like it!! ;)
  8. LRKingII
    LRKingII New Member
    679
    132
    Idaho
    Just make sure if the ready light is on the car is moving. :D LOL
  9. wfolta
    wfolta Active Member
    366
    146
    Washington DC
    2018 Prius
    If you only counted MPG while the car was moving, most users would wonder why they were buying so much gas for a car that got such incredible mileage.
    And once you start counting "only moving", why not go farther and only count "only moving fast"? Or "only moving efficiently"?
    It'd be interesting if your philosophy applied to everything. Imagine me telling the electric company: "You can only count watt-hours spent while I was home. I mean, just because I leave all my lights on all day while I'm at work doesn't mean I should have to pay for light that I don't use."
    Or how about refunds at restaurants for unused food/drink? "I only drank half of my glass of tea, so I want you to charge me half price. And I don't like carrots so I didn't eat them, and I figure that's 25% of my meal, so refund it to me."
    My wife actually had a renter at one point who was going on a trip overseas for 3 weeks and so only wanted to pay 1/4 of her rent, since she wouldn't be there for 3/4 of the month. My wife said no. I'd have said, "Sure, as long as you don't mind your stuff sitting on the sidewalk for 3 weeks."
  10. fuzzy1
    10,332
    The gas was consumed, and it wasn't free.
    Excluding that gas would reward bad warm-up behavior, encouraging lots of stationary fuel burn to get the engine up to ideal operating temperature. The resulting MPG displays would be fiction, with the 'best' mpg results produced by those wasting the most fuel. That is what would really be 'lame'.
  11. Mitchellsprius
    Mitchellsprius New Member
    91
    monterey
    I have the same question is their a life time average? Some people have reported it but I can not find it on the display.
  12. nola_Prius
    405
    62
    New Orleans
    Because moving = moving. Not moving = not moving.
    Cute comparison, but hardly the same thing.
    Miles per gallon is a measure of distance over fuel consumed.
    In my opinion, both values are needed to calculate. If no distance was gained, why would DISTANCE per gallon have anything to do with it? It's not my philosophy. It's just the idea that a MPG rating would be a simple way to tell you how efficiently a car DRIVES - not how efficiently it drives AND sits with the motor running.
    That would be wonderful, but who is talking about refunds?
    I'm not talking about how much gas is used while you coast to a stop, and that it shouldn't be calculated into your MPG average... I'm talking about the calculation of simply GAS USED WHILE YOUR CAR IS RUNNING AND *DRIVING/MOVING*.
  13. nola_Prius
    405
    62
    New Orleans
    I have come to the assumption that some people simply leave either Trip A or Trip B as a running total, without ever resetting it.
    If I were designing the car, I'd have included a lifetime MPG calculation (of while you were DRIVING!!!), that could not be reset.
  14. fuzzy1
    10,332
    Unfortunately, there is no honest way to separate driving efficiency from fuel burned while not moving. Engines must be warmed to and maintained at operating temperature to operate efficiently. Fuel burned while not moving is a very important contributor to that warming process.
    Idle fuel burned while stopped at stop signs and traffic lights is a big factor in city economy. Excluding it would not change Prius' mpgs, but would significantly boost the claimed mpgs of non-hybrids.
    Excluding non-moving fuel would lead to lots of MPG ratings cheating, with nearly all the benefit going to gas wasters. The Prius' efficiency rating advantage over non-hybrids would significantly shrink.
    This is similar to the plug-in hybrid claims of '100+ mpg' without any mention of the electricity required to achieve that result. From my engineering viewpoint, the exclusion is a fraud.
