MPH display - Scanguage vs dashboard
Discussion in 'Gen 2 Prius Technical Discussion' started by eurosteve, Sep 26, 2008.
  1. eurosteve
    eurosteve Member
    122
    Watkins Glen, New York
    I've noticed a difference in the MPH display on the Scanguage vs. the dashboard. The Scanguage shows my speed at 1 -2 miles per hour less than the dashboard display. I was surprised to see this - thinking that both the scanguage and the dashboard readout are accessing the same computer in the car. It looks like the MPG also shows as less on the Scanguage.
    Any idea why there would be a discrepancy? And then the big question - which one is correct?
  2. Dozzer
    Dozzer Prius Noob
    189
    Swansea, UK
    It could be the speedometer is calibrated slightly higher than actual speed.
    For example Germany have a law that states the speedo must show 7% more than actual... so 100mph actual = 107mph indicated.
    I have the same problem here in the UK.. GPS (3 different types and a radar gun - used on a local racetrack) show the actual speed at 3.5mph lower than speedo indicated speed.
    I'd prefer it to be spot on to be honest.. especially with stock wheels and tyres.
    Anyone know how to calibrate the speedo ?
  3. David Beale
    David Beale Senior Member
    5,963
    1,985
    Edmonton Alberta
    I doubt it's a calibration issue. The display shows what the OBDII data shows. My Scangauge II reads exactly what the speedo does. It could be a time delay if your speed is changing, or it could be roundoff errors.
    I -think- you can change how the Scanguage II calculates speed, ie, enter corrections. Perhaps a correction has been entered into it (for mileage correction)?
  4. Wa1hog
    Wa1hog Old Blind Hippie
    95
    South West New Hampshire
    I have a GPS which also reads 1.5 to 2 MPH less than the dash. Im pretty sure all Prius' are calibrated high.
  5. archae86
    archae86 Member
    153
    24
    Albuquerque, NM
    My GPS (a Garmin GPS V) reads about 1 mph lower than the dashboard display on my Prius at 66 mph indicated on the dash, about 65 on the GPS. (original tires at about 15,000 miles)
    As to German cars reading low by law: if true in Germany it seems not to be borne out on my US models. My 1987 BMW 325i and my 2002 Audi A4 both read very, very close to my GPS. 7% high is many times the margin of any error they have. My 1975 2002 predated my GPS, but until it had a failure it did not read anywhere near that much too high either (calibrated on freeway mile markers over many mile stretches).
  6. eurosteve
    eurosteve Member
    122
    My GPS (Magellan) speed matches the Scanguage speed - both are 1 - 2 mph slower than the dashboard display at a steady 70 mph with cruise control on flat highway.
  7. ken1784
    ken1784 SuperMID designer
    2,943
    1,380
    67
    Yokohama, JAPAN
    This kind of questions were raised many times.
    http://priuschat.com/forums/care-maintenance-troubleshooting/52888-speedometer-calibration.html
    The speedometer reading is intentionally biased to meet the UN ECE Regulation.
    http://www.unece.org/trans/main/wp29/wp29regs/39rv1e.pdf
    Japanese NHW11 meets old Japanese regulation.
    Japanese NHW20 meets the UN ECE regulation.
    Ken@Japan
  8. eurosteve
    eurosteve Member
    122
    Thanks everyone. So I conclude from all of this that my REAL speed is what is displayed on my Scanguage (and my GPS, since they agree) and the speed shown on the dash is the number that's wrong. Interesting tidbit.
    Next question. Does this then artifically inflate the number of miles shown on the odometer?
  9. ken1784
    2,943
    1,380
    67
    Yokohama, JAPAN
    The odometer is another story.
    My observation is the odometer is very accurate, within 0.5% error.
    Ken@Japan
  10. nownow
    nownow Junior Member
    70
    Pinehurst NC
    Not that it's much more than echoing the opinions already posted, but I'll weigh in. My Jetta was 3-4 MPH over at 70 with a stock tire size, until I changed the 225/45-R17 tires to 225/50-R17 tires. As I expected, now it's right on, according to the little radar stations that the troopers set up near construction zones. Oh, and because of the size change, my odometer now reads 100 miles for every 105 traveled, so that was right on before.
    When bringing home the Prius and talking to my wife (following in the Jetta) the Prius was reading 1-2 MPH over the Jetta, i.e. 1-2 MPH over actual.
    Scientific? No. Groundbreaking? No. Just another data point.
    ~ J
  11. zenMachine
    zenMachine Just another Onionhead
    3,355
    300
    According to the specs Ken provided...
  12. ekpolk
    ekpolk What could possibly...
    548
    176
    Pensacola & Vero Beach FL
    2018 Prius
    Two Eco
    FWIW, this is seemingly a pretty consistent phenomenon. The speedo in the TCH does the same thing. When the gauge is indicating 80 mph, the GPS (Magellan) says 68. My SG will be coming soon, and I expect the same from it.
