Mud guards front & rear - any MPG comments ??
Discussion in 'Gen 2 Prius Main Forum' started by wtfjr, Aug 19, 2006.
  1. wtfjr
    wtfjr New Member
    38
    Hi All
    I have a set of front & rear Toyota mud guards & before I put them on are there any comments on their affect/effect on gas mileage ?
    Thanks !!
    Bill in FL
  2. TheForce
    3,461
    537
    Wheelersburg, Ohio
    There is very little if any MPG drop. I did not see any drop when I installed mine but I also installed racing hubcaps just after the mud guard install so I did not get to drive it much to see a difference. I did see about a 2MPG increase when installing the hubcaps but your mileage may vary.
  3. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    Yup, there was much speculation when the guards were first 'discovered', but it's pretty clear now that they have no measurable impact on MPG.
  4. Rangerdavid
    Rangerdavid Senior Member
    1,362
    52
    Boone, North Carolina
    Three Touring
    I installed mine last weekend. They were very easy to install. you do have to take off the rear wheels though, but its really no biggie. I have noticed no, absolutely no difference in MPG, handeling, and I think they do give a nice "finished" look to the vehicle. It looks quite good without them as well though.
    So in essence, I needed to have added protection since I live on a gravel road. I'm glad I put them on and recommend that if you decide to put them on, go for it. I dont think you will experience any difference in MPG, wind noise, driveability, etc. good luck.!!
  5. OverTork
    OverTork Junior Member
    68
    Northville, MI
    I've had the splash guards since spring and I have seen no decrease in MPG.
  6. Tideland Prius
    16,402
    Shouldn't matter. They're standard equipment in Canada.
  7. Rest
    Rest Active Member
    1,210
    CA
    The only negative effect splash guards have on the Prius is you have to drill several holes in the car. This bothers me because then you can never take them off without it not looking stock.
  8. Tideland Prius
    16,402
    <div class='quotetop'>QUOTE(Rest @ Oct 26 2006, 03:20 AM) [snapback]338485[/snapback]</div>
    lol. My car came with mudguard (standard in Canada) so that is stock to me!
