Multi-Information Display - Nav
Discussion in 'Gen 4 Prius Audio and Electronics' started by Carl - NW Ohio, Feb 19, 2017.
  1. Carl - NW Ohio
    Carl - NW Ohio New Member
    Ohio
    Since the dealer had to take the dash out to replace the passenger airbag, the MID no longer shows intersection alerts from the Nav. I didn't realize how much I like that feature. I have searched the owner's manual but haven't found a setting to adjust. Any ideas? Or is this a dealer thing?
  2. 'LectroFuel
    'LectroFuel Senior Member
    880
    673
    San Juan Capistrano, CA
    What's the intersection alert?
  3. Elektroingenieur
    2,515
    3,275
    Three Touring
    The setting isn’t in the owner’s manual, alas, though it is covered in the New Car Features service manual. Using the buttons on the right side of the steering wheel, go to the Settings page of the multi-information display, and make sure Meter Customize > Pop-up Display On/Off > Navigation is set to On.
    Also, on the navigation system, under APPS > Setup > Navigation > Detailed Navi. Settings, make sure the Pop-up Information checkbox is selected.
    If these settings don’t restore the expected behavior, I’d suggest taking the car back to the dealer that serviced it, unless you have a way to check for CAN bus communications failures yourself.
    RCO likes this.
  4. Carl - NW Ohio
    Ohio
    Thanks for your detailed reply. Checked these items and they were correct. I tried turning both off and then back on again and even back to default. No luck. I did stop by the dealer and took a drive with a salesperson. He could not figure it out. Asked Service and they referred me to Sales. So I'm stuck for now but hoping it just starts working again.
  5. Carl - NW Ohio
    Ohio
    And just like that, today it started working again.
