multiple scanguage
Discussion in 'Gen 3 Prius Accessories and Modifications' started by cproaudio, Nov 6, 2010.
  1. cproaudio
    cproaudio Speedlock Overrider
    2,401
    760
    CA
    Is it possible to use 2 scanguages for 2010 Prius? How would the connections go?
  2. fuzzy1
    10,332
    Yes. Isn't that a standard Ethernet jack on the side and back?
  3. Bob64
    1,540
    93
    Virginia
    Yes. Probably.
    Connect one end to the other. Use a "straight through" cat5 patch cable. Don't use a crossover cable.
  4. cproaudio
    2,401
    760
    CA
    Yes I know it's standard cat5 cable. So the port on the side is for daisy chaining?
  5. ccdisce
    ccdisce Active Member
    259
    187
    Stone Mtn GA USA
    Yes that was my understanding when I bought mine a year ago, I do not think that the dasiy chain cable was specified tho.
    You may want to to Ohm out the Scangauge's cable and with the following references to see that the power pair and the CAN pair get accross the the appropriate pins on the 2nd unit with whatever cable you chose or make.
    You do not want to mess up the CAN pair.
    On-board diagnostics - Wikipedia, the free encyclopedia
    [ame=http://en.wikipedia.org/wiki/Category_5_cable]Category 5 cable - Wikipedia, the free encyclopedia[/ame]
  6. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    I'm prepping for a 2xSG setup.
    My comments are rather fuzzy because I don't have any real EE
    experience.
    By visual inspection, the ethernet cable that I have has the same left-to-
    right color sequence on both ends.
    I have hooked everything up, and the two SGs work fine.
    FWIW, my two SGs are different series; one a x.15, the other x.16 -- IIRC
    The x.15 comes off the OBD plug and the x.16 comes off that.
