Multiple Warning Icons And Lights
Discussion in 'Gen 2 Prius Technical Discussion' started by Poosey, Sep 9, 2011.
  1. Poosey
    Poosey Junior Member
    16
    SW Florida
    2009 Prius w/ 29,750 mi [Maint Req Light came on at ~28,000 mi]
    SW Florida
    I am getting a Master Warning Light (triangle), a Hybrid System Warning icon, a VSC light, a (red) Brake Warning icon and a Check Engine icon. When the car starts, the A/C is fine but quickly loses cooling output especially with full throttle. regardless of manual or auto setting. Throttle feels a bit spongy and slightly unresponsive.
    4 blue bars on charge and everything else appears OK. :D
    Outside of the need for a visit to Toyota :rant:, any suggestions or comments?
    TIA
  2. Hal W
    Hal W New Member
    872
    53
    Grand Forks,B.C. Canada
    First thing you want to check is the 12v battery. Insure that it is putting out 12v to 12.6 volts. If lower, then that is probably the problem! Your 12 volt will need to be charged or replaced. Hal
  3. Patrick Wong
    18,200
    6,490
    When the Prius is READY, look at the inverter coolant reservoir. Do you see fluid turbulence which shows the inverter coolant pump is running?
    If no, then a failed inverter coolant pump is your car's problem.
  4. Poosey
    16
    SW Florida
    Will do and thanks for the advice! :)
  5. Poosey
    16
    SW Florida
    Going to look now, appreciate your response. :)
  6. Poosey
    16
    SW Florida
    IC pump running ok. :)
  7. Poosey
    16
    SW Florida
    Looks good at slightly over 12v. :rockon:
  8. Patrick Wong
    18,200
    6,490
    I think it is time for you to schedule a dealer visit; whatever problem the car has should be covered under warranty.
  9. Poosey
    16
    SW Florida
    Hal, going to have to back off on my prior response that all is well. My volt meter may be on the fritz. :rolleyes:
  10. Poosey
    16
    SW Florida
    Yeah, Patrick, I've come to the same conclusion. :( Oh, well, it's a great car with this one problem to date. :)
  11. Hal W
    Hal W New Member
    872
    53
    Poosey , it is best to let the car sit over night ,then check before starting. There is a way you can check your voltage on the display panel. Do a search, Hal
  12. Poosey
    16
    SW Florida
  13. Poosey
    16
    SW Florida
    Returned from dealer...inverter coolant pump needed replacing...:mad:...learned a lesson. When looking at the flow at the reservoir, make sure you see real bubbles and not car vibrating the fluid. :embarassed:
    I had looked at this video
    TeacherTube Videos - Prius inverter turbulence
    and took from that a wrong impression. Warranty covered the fix.
    Thanks again to everyone! :rockon:
  14. Hal W
    Hal W New Member
    872
    53
    Yes you have to look for coolant flow[Movement] Good exercise anyway! You learned something. I was going to mention this issue [pump] next after you checked the 12V.Take care, Hal
  15. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    511
    63
    Another reason to check the inverter coolant pump in IG-ON mode (not READY) so that the engine would not be running and car would be nice and quiet and easy to hear the pump running and see the fluid moving in the reservoir. :)
  16. eterry2
    eterry2 New Member
    23
    Houston
    looks like my similar symptoms is the inverter pump. is it ok to drive it?
  17. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    It's a cooling issue, so it all depends on how it is driven and temperature. A short trip to the dealer on a cool day is fine. Going through the mountains is not.
    Tom
