Musty A/C - Dealer service
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by RoyThePriusGuy, Jul 22, 2011.
  1. RoyThePriusGuy
    RoyThePriusGuy New Member
    186
    25
    phoenix
    Has anyone brought their G3 in for AC service to remove the musty/mildew odor from AC evaporator? Mine smells for a couple seconds after start.
    Rather than blindly go to my dealer for the $$$ Toyota AC cleansing service - anyone have experience with this. How much, effectiveness, etc/
    Thanks,
  2. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    I believe the standard advice is to shut off the AC 1 or 2 blocks from your destination and put it on Outside air full blast. Of course, take the AC filter off and clean it. You can also spray the filter (lightly) with some air freshener. I also spray the inside of the car once in a while and close the doors quickly before bedding down. :D PS I should not think it a problem in Arizona.
  3. RoyThePriusGuy
    186
    25
    phoenix
    Thanks,
    I NOW turn off AC blocks way and ensure it's out of Recirc as much as possible. But I wasn't prudent for the 1st 1 1/2 years. One would think new cars esp in climate as this would not have this issue. It's definitely some mildew in coli/evap.
    Just not sure how effective the dealer AC service is and worth the cost. I simply do not trust dealer personnel in their sales yada...
  4. GSW
    GSW PRIUS POWER
    537
    74
    Jacksonville
    Roy, you might try some scented Lysol on the A/C filter to see if that helps. I think Fram also makes a scented filter but I don't think it will kill any mildew or fungus in the system. Just turning off the A/C before I get home has always helped me keep my system smell fresh as well.
  5. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    I don't have this issue on my Prius, but did on a previous car, and based on a recommendation I saw on another car forum, got a bottle of Wurth A/C & Heating System Treatment. Easy to use, and I had the car for 2 years afterwards and the odor never returned:
    Wurth A/C & Heating System Treatment 6 oz.
  6. 32kcolors
    32kcolors Senior Member
    5,683
    953
    124
    Redondo Beach, CA
    That's caused by leaving it in recirc for too long. Make sure it's getting outside air through and the problem should resolve itself.
  7. FBear
    FBear Senior Member
    355
    23
    Maplewood, NJ
    2015 Prius v wagon
    You also might want to check the pan on the interior unit. There is a small rubber pipe that sticks out of the pan that allows the water that has condensed to leak out of the pan. If the pipe is blocked you will have stale water sitting in the condensor pan an mold will eventually grow. to test this put a running hose with near the base of the windshield you should see water coming out near the front of the footwell on the passenger side. If not the hose is clogged. Once you get in un-clogged using compressed air. You can pour a weak solution of water in bleach near the base of the windshield, try not to get it on everything. This should eliminate any mold growing in the pan.
  8. katiesdad7
    katiesdad7 Member
    172
    25
    Stuart, FL
    Is this covered under the warranty?
  9. phoenixgreg
    phoenixgreg Senior member
    1,157
    291
    66
    Phoenix
    Once you get mold growing in the evaporator coils, your only option is to clean the fins. There are evaporator coil cleaners out there, but I can't locate where the evap coil is in a Prius.
    On my prior car, there was an opening in the firewall giving easy access to the coils and fins. You could spray the cleaner in there and rinse it 10 minutes later and all kinds of crud would come out the drain tube.
    If anyone knows how to access the evap coils, the knowledge would be appreciated.
