My 120K service is coming up....
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by cyberpriusII, Jun 14, 2018.
  1. cyberpriusII
    cyberpriusII Prodigyplace says I'm Super Kris
    1,150
    1,683
    Iowa
    So, I know that is the big dog service.
    I will be doing it at the dealership. They are at least honest, but very pricey. But I have a 20 percent off coupon that a service advisor slipped to me one day when we were chatting (nice guy for a dealership service advisor).
    Anyway....
    Other than what Toyota says....is there anything I should avoid, or, anything I should add.
    I replaced the engine water pump at 50K (leaking) and had the transaxle fluid replaced at 75K.
    Thinking -- IIRC -- Patrick Wong -- in his quest to cost me $$ -- said I still need to replace all the coolant and need to redo the drain and replace of the transaxle. Even considering I did the water pump at 50K and the trans at 75K.
    Just joking a bit. Patrick is fantastic!>LLLLL>>>>
    So, anything else I should know, other than placing my first-born on the block.
    Car is doing GREAT! btw.
    kris
    51,033
    you should have handed him that coupon back and told him you're not that kind of woman!:mad:
    Raytheeagle and Starship16 like this.
  3. cyberpriusII
    1,150
    1,683
    Iowa
    Oh, but I am that kind of woman, Bisco. Run on out to Oregon, see what I give you! :D:eek::rolleyes:
    Starship16 likes this.
    51,033
    i'm not sure i want to find out!:eek: it disturbs me that attractive women get free stuff and nice treatment. i'm going to start a me too movement, it has a nice ring to it.(y)
    Raytheeagle likes this.
  5. bisco
    51,033
    but on a more serious note, did they change your coolant with the water pump?
  6. cyberpriusII
    1,150
    1,683
    Iowa
    Ah, Bisco, I am 5'10" and very skinny (or was/am until recently). Not the Kim K. type. So do not think I got any special treatment. I am just naturally nice to people and they respond.
    As my husband says though, I am very wiry. Anyway, enough off-topic. I really THINK that the receipt that I got with the WP swap-out charged me for a gallon of coolant, which means they did not change out the coolant.
    Which is why, Patrick said I need to have it all changed out when I did the 120K
  7. bisco
    51,033
    sounds like you need the full boat plus tranny fluid then. what about plugs?
  8. JC91006
    16,656
    8,506
    120k is just simple fluids and plugs. Unless you're going to bleed the brakes, any mechanic can perform this service without special tools
    1 coolant
    2 transaxle fluid
    3 bleed brakes and clean
    4 plugs
    5 Air filters
  9. Mendel Leisk
    40,484
    If bleed brakes equals change brake fluid, and especially if it's never been done something definitely worth doing. Toyota Canada says every 3 years or 30K miles now. And Honda Canada has been saying 3 years regardless of miles, in a couple of centuries...
    Air filters, meh, check them and replace if really needed, but certainly don't pay a mechanic to do it.
    Starship16 and cyberpriusII like this.
  10. cyberpriusII
    1,150
    1,683
    Iowa
    Yes, brakes have never been touched.
  11. bisco
    51,033
    are they on the us schedule?
  12. Patrick Wong
    18,200
    6,491
    Here's what I would add:
    1. Was the serpentine belt previously changed (for example when the engine coolant pump was replaced)? If not, that should definitely be done now.
    2. If the front struts and rear shocks have not previously been replaced, they should be replaced now. I understand that much of your driving had been in rural areas on gravel/dirt roads, which will stress the suspension more than on pavement. So you can expect your suspension needs help. You don't necessarily need the dealer to do that work if you can find an independent to install KYB-branded parts. The front struts also need the top strut mounts and the top spring insulators (which include the pleated cover) to be replaced.
    A 20% off coupon is pretty normal when you consider the list prices of the services.
  13. Mendel Leisk
    40,484
    Oy...
    Every 3 years or 30K miles... :(
  14. Patrick Wong
    18,200
    6,491
    Periodic brake fluid replacement is not on the US 2G maintenance schedule. Personally I would do that work only as part of replacing the brake actuator assembly, not as a preventive service, due to the concern that the fluid replacement process may stress the brake actuator more than normal use of the brakes do, and prompt an actuator failure.
  15. Mendel Leisk
    40,484
    Different folks I guess. I mean, they say the transaxle fluid is lifetime too.
    FWIW, the 3rd gen has a Repair Manual instruction for brake fluid replacement, without Techstream. IIRC 2nd gen Repair Manual has no such instruction, and it's not something you want to fly blind on.
    If it's as easy as 3rd gen, it's about an hours work, with an assistant pumping the brake pedal, and costs a couple of pint bottles of Toyota DOT 3 fluid. A significant "if" though.
    @NutzAboutBolts has the definitive video on 3rd gen brake fluid replacement.
  16. edthefox5
    edthefox5 Senior Member
    10,096
    4,830
    Clearwater, Florida
    Chris forget all that start contemplating the hybrid battery failure. If the car has not thrown any codes yet
    It’s ripe for a battery reconditioning because it does not matter at all how nice and maintained the chassis is if the battery tanks.
    It’s the #1 post now on a G2.
  17. JC91006
    16,656
    8,506
    If it's been close to 100k miles since your inverter pump has been changed, I would put that on the "to do" list. That's quickly becoming a major failure as many of the recalled replacements are all coming up to needing a replacement again.
