my feet are freezing!!!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by cdf, Jan 27, 2009.
  1. cdf
    cdf New Member
    northern virginia usa
    i swear i didn't have this problem last winter (I'm in a relatively mild climate). I have NO heat in the footwell and I'm cold from the knees down. The regular vents blast a furnace of delightful heat but nada at the lower levels. I do not use the automatic heat as a rule because the fan noise is too much. If i'm on defrost setting, the only thing that's warm is my right hand.
    my 2005 prius suffered extensive ($6k) cosmetic body damage in a tornado/hail storm. could the body shop have somehow switched the foot vent off?
    anyone know where the control for the foot vent is?
    oh, btw, I'm clueless about all matters that require a tool. THANKS
  2. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    I recommend that you use Auto AC and let the system work as designed. The fan noise will reduce as the car warms. When you are in the defrost mode, most of the air flow will be directed toward the windshield with some towards the dise windows.
  3. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    Sure, something could have been changed by the body shop. It's also possible that an actuator has stuck or died. I think it's time for a trip to the dealer, at least for a diagnosis.
    Tom
  4. richard schumacher
    7,664
    1,042
    United States
    Beyond trying "Auto A/C", push the "Climate" button and study the screen. Every automatic function can be over-ridden manually. Have the owner's manual handy for reference.
  5. m jones
    m jones New Member
    DUBLIN ,IRELAND
    Hi , I have a similar problem with my GEN 3 , did you solve issue of Cold feet ?
