My Recent Trip: Expressways…ugh, bad mileage
Discussion in 'Prius c Fuel Economy' started by Fahfoofnik, Nov 13, 2013.
  1. Fahfoofnik
    Fahfoofnik Member
    98
    32
    Plainfield, IL
    Believe me, I'm fully aware that a road trip on the expressways will take a chunk out of a Prius' gas mileage. I didn't think it'd be THIS much of a hit, however.
    Here's my trip details: 3 people (wife + I, she's about 120lbs & I'm 185lbs; my 50lb son who's 8), 5-6 bags/luggage, a small cooler, pillows. The trip: to/from our area to stay at my sister's home in Cincinnati.
    Around 445 miles, round trip. We took a different route one way that added probably about 50 miles or so. I started out the trip with nearly a full tank; just one tick off the fuel meter, it'd gone off the meter the morning on my way home from work.
    Expressways: speed limits ranged from 55mph to 70mph, save the construction zones (usually 45mph, a few were 35mph). So the trip was about 90% or so expressway. I drove around Cinci one day, no more than 20 miles or so in the city…and then stopped in Champaign, IL on the way home & did another 20-25 miles or so in town.
    My driving habits: drove at posted speed limit in speed traps; otherwise, ever more than 5mph over the limit. Used cruise control nearly completely, save for a few hills where I needed to push the pedal down to get up the hill.
    I had minimal climate control; I used the "heat," temp on anywhere from 66F to 69F, sometimes the defroster for a few minutes. Fan speed always on the lowest or second-lowest.
    Always filled up with 87 octane. Here's what I got over the course of the Friday-Monday trip. Stats from the fill up:
    15 11/11/13 296.8 7.02 42.3 3.090 25% [​IMG]
    14 11/11/13 284.9 7.33 38.9 2.999 15% [​IMG]
    13 11/8/13 348.6 7.82 44.6 2.990 25%
    …41.96. That's my mileage.
    Awful.
    About 75% of my driving is usually city driving (before taking this trip), and according to the Prius C's computer, I'd been getting 58mpg on my trip B odometer, and as Fuelly says around 55MPG.
    I tried to be cautious with accelerating and braking, sometimes when merging you have to "floor it" in order to merge, but I kept that to a minimum.
    So I ask you Prius C experts here: should I be happy with this? Or is this (what I deem) crappy MPG normal for 3 people, baggage & expressway travel?
  2. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    Tire pressure? Did you check to make sure there isn't anything blocking the vent in the back seat?
  3. Fahfoofnik
    Fahfoofnik Member
    98
    32
    Plainfield, IL
    Yes. As a matter of fact, the very day before we hit the road, I took my car to the dealer for the 5,000 mile service. Nothing was blocking the vent, my son sits on a car seat where that compartment is, but he's a shorty so there was nothing on the floor covering the vent.
  4. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    Did they adjust your tire pressure? Did you check it after?
  5. Fahfoofnik
    Fahfoofnik Member
    98
    32
    Plainfield, IL
    No I did not. On the several print outs I received from the dealer detailing what was done to my car, there was a checkmark next to something like "Checked/adjusted tire pressure."
  6. sisharp
    sisharp Member
    46
    29
    South Carolina
    Don't worry about it. With the colder temps this is normal. The heater doesn't affect much since you were driving most of the time. Having the heater on in city driving would drop your mpg since the engine would try to keep warm. Anywho, with the added weight, that also drops the mpg since the engine works harder.
    By driving around 5 over you use more gas right there.
    By using the cruise control, the engine always try to maintain the speed and if there were any hills along the way which you didn't add gas to, then the engine just mashed it for you to maintain say 70 which adds up to using more gas over several hills. Cruise control is rarely a good choice when going for mpg.
    Besides with an mpg of 41.96 you only lost 8.79% mpg from estimated. Remember, the prius c gets 46 on the highway.
    If you were in an SUV that gets 30 mpg and you get an average of 27 you may not think it's that bad but it would be worse than what you achieved since it translates to a drop of 10% mpg.
    Your biggest enemy is the cold though. No way around it.
    minkus and Fahfoofnik like this.
  7. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    That indicates they adjusted your pressure. I'm "assuming" you normally run your tp higher than manufacturers suggested rate. That will hurt you a little. If they dropped it lower than 30 that will hurt you significantly.
  8. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    65-70 degrees isn't enough to drop it to the low 40s...
  9. sisharp
    sisharp Member
    46
    29
    South Carolina
    In Cincinnati it's gotten to the low 40's in the past 2 weeks and even lower recently. The temp set in the climate control doesn't affect it but the outside temperature does.
    Also, last friday it was particularly cold throughout the day in chicago. Which is what his location says. Last friday began below 40 and maxxed out to around 45 degrees.
    This plus the winter fuel blend doesn't make for the best driving conditions.
  10. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    I read his thermostat temp as his outside air. Sorry.
  11. Fahfoofnik
    Fahfoofnik Member
    98
    32
    Plainfield, IL
    Ok, so sounds like nothing to worry about. That's fine. It just concerned me, as I thought I'd done everything right (didn't block the vent, had the car checked by the dealer before hitting the road, etc.).
    Was just shocking to see a tank of fuel go from 52-56MPG all the way down to 42-44MPG.
  12. Fahfoofnik
    Fahfoofnik Member
    98
    32
    Plainfield, IL
    No, to be honest, I've never adjusted the tire pressure higher than what the sidewall/owners' manual said. I have read several threads here about how "over-inflating" helps with achieving higher MPG, but I'm too scared to do it.
  13. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    Which is it? Sidewall is much higher than what the owners manual says.
  14. Hodr
    Hodr Junior Member
    23
    my dealer set the pressure at 50 psi, but it seems to be fine.
    Nexus 7 ?
    ztanos likes this.
  15. Yikes...the highest I've had mine is 44 psi, and I could tell it was high because it was on a freak weekend with 70 degrees and electric braking on a straight road wasn't enough, my car just kept on going straight.
    On the hottest summer day, I had the A/C up to half and it was 97 degrees and still topped off at 53 mpg. So, I would not be happy with 41 mpg. My first guess is low tire pressure, but it sounds like something else is going on. So to ask Fahfoofnik: Did you have your oil changed at the dealer as well? How high up did they fill the oil? I've heard that too much oil hurts fuel economy. How much of your road trip driving was into the wind?
    Fahfoofnik likes this.
  16. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    It was the cold weather. Most assuredly.
  17. orenji
    orenji Senior Member
    5,886
    3,487
    With all that weight in the car, you should be happy, what did you expect to get 60 MPG?
    This car with driver only gets me 55 to 60 MPG, on highway. Add a 2nd person and I can get high 40's on the highway.
  18. Mendel Leisk
    40,238
    I think it's mostly the speed that's hurting your mileage. Things you can do:
    1. Stay to the right and under the limit.
    2. Choose secondary, lower speed highways.
    3. Drive with load, ie: let your speed fall off on short upgrades, recoup it on the far side.
    4. Drive strategically, keep a good buffer ahead (don't sweat it if someone "takes" the space), coast up to slow downs.
    5. Raise those tire pressures, moderately at first.
  19. Fahfoofnik
    Fahfoofnik Member
    98
    32
    Plainfield, IL
    Owner's Manual is what I've gone by, sorry…should've clarified.
    ztanos likes this.
  20. Fahfoofnik
    Fahfoofnik Member
    98
    32
    Plainfield, IL
    No, like I said in the original post, I wasn't expecting some astronomical MPG with the 2 extra people + luggage in colder weather. The drop off from 54-56MPG per tank to 41-44MPG just seemed really steep to me. I'm learning now that this drop off is considered normal.
    orenji likes this.
