My solutiion to clean the Oil Spill
Discussion in 'Fred's House of Pancakes' started by Chuck., May 15, 2010.
  1. Chuck.
    2,766
    1,510
    Lewisville, TX (Dallas area)
    As Spencer suggested.
    50,813
    kittylitty.
  3. daniel
    14,487
    1,519
    Spokane, WA
    So, all they need to do is dump about a million pounds of kitty litter into the Gulf of Mexico, and then follow it with a few hundred thousand gallons of dish soap? Hmmm. I suspect there's a flaw there somewhere. :confused:
  4. Chuck.
    2,766
    1,510
    It's no worse a solution to the couple that have failed by the #4 corporation in the world that felt they did not need an emergency plan, then begs to public for ideas. :eek:
    Currently BP is trying a "Junk Shot" - this suggestion is a crap shot. :D
  5. dogfriend
    7,512
    1,188
    Carmichael, CA
    Instead of a "junk shot", BP should try a "kitty litter shot" directly into the pipe followed by a "cat piss shot" to clump the litter in place.* :madgrin:
    * If BP actually implements this plan, I am entitled to 10% of the money saved over the clean up needed after they successfully close off the well 3 months from now. Please forward the cost analysis to me prior to final settlement for review.
  6. a_gray_prius
    2,927
    783
    IL
    My solution to the oil spill? $200/bbl oil.
  7. ctmurray
    ctmurray Member
    121
    Actually the higher the price for oil, the more the oil companies will try to get the oil that is hard to get. So they can afford to drill deeper and deeper waters (which is more expensive for them). Not sure I have an answer, I am just pointing out some economic issues.
  8. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    For the most part, the use of "dispersants," in this whimsy the dish
    soap, is considered a drastic measure... microscopic oil droplets
    suspended below the surface and hence "out of sight, out of mind" in
    the water column are not only difficult/impossible to collect, but play
    a role in the degredation of the aquatic habitat/environment in addition
    to chemical elements of the crude oil that are water soluble and
    disperse directly into the water column.
    "The researchers also were testing the effects of large amounts of
    subsea oil on oxygen levels in the water. The oil can deplete oxygen in
    water, harming plankton and other tiny creatures that serve as food
    for a wide variety of sea creatures.
    Oxygen levels in some areas have dropped 30 percent and should
    continue to drop, Joye said.
    The Environmental Protection Agency gave BP the go-ahead on
    Saturday to use dispersants, chemicals that break the oil into small
    droplets and keep it from rising to the surface.
    "It appears that the application of the sub-sea dispersant is actually
    working," BP Chief Operating Officer Doug Suttles said. "The oil in the
    vicinity of the well is diminished from previous observations."
    At least 210,000 gallons of oil have been gushing into the Gulf each
    day since the Deepwater Horizon exploded on April 20, and some
    independent scientists think the leak may be 10 times that bad.
    Environmentalists - and some leaders in the fishing and oil-spill
    cleanup industries - have raised concerns about the chemical
    dispersants.
    "Cosmetically, it makes it seem that the oil has gone away," said Tom
    Manton, the retired president and CEO of the International Oil Spill
    Control Corporation. "But the oil doesn't go away. It ends up in small
    drops, either on the beach or on the seabed...In many cases, the
    dispersants are more polluting to the water than the actual oil is."
    The EPA and Coast Guard, however, say the dispersants are "generally
    less harmful" than oil and will biodegrade in a shorter time span.
    Read more.
  9. eagle33199
    eagle33199 Platinum Member
    5,122
    268
    2015 Prius v wagon
    I say we charter a boat and go down there and skim some of this oil off the water... a thousand gallons and i won't care about the price of gas for a long, long time!
  10. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    I say we dump ALL the lawyers into the Gulf, and let them clean it up......
  11. dogfriend
    7,512
    1,188
    Carmichael, CA
    That would only add to the oily residue. :madgrin:
  12. a_gray_prius
    2,927
    783
    IL
    At that price the oil might be sufficiently expensive that spills/loss of product events become essentially catastrophic to the top line. It might also then be economically viable to try reclaiming the spill.
  13. HumveeSki
    HumveeSki New Member
    Maryland
    I think they should just let it keep bubbling and then pay it forward by purchasing carbon credits like the rest of the tax evading corporations who do nothing to really stop emissions, etc. That should fix everything right? LOL.
  14. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    Please, please, PLEASE use biodegradable dish soap, okay? Please?
