Nasty Hybrid Cooling Fan Grill After 90k Miles (photos)
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by CivicRydr, Dec 26, 2016.
  1. CivicRydr
    CivicRydr Junior Member
    San Francisco
    My car displayed a warning message for the hybrid battery cooling system. So I took a look at the air inlet and found it dirty, but after removing the cover I was shocked to find a complete mess on top of the grill.
    [​IMG] [​IMG]
    So I cleaned it all up and air should be flowing more smoothly.
    Does anyone know how I can reset the system so that the warning message is no longer displayed?
    Data Daedalus likes this.
  2. mrbigh
    3,686
    699
    Long Island, NY
    yes, go to the dealer ......
  3. yeldogt
    yeldogt Active Member
    810
    313
    NE
    May need to check that out -- does the trim just pop off?
    #3 yeldogt, Dec 26, 2016
    50,813
    e u gross!:eek: what cause that? r u 2nd owner? that's disgusting, never seen anything like it.
    otoh, nice to know they've added a sensor/warning.
    Raytheeagle likes this.
  5. ILuvMyPriusToo
    ILuvMyPriusToo Senior Member
    778
    514
    Outside Philly, PA
    Interesting to know if it resets itself after a few starts now that air flow has been restored.
  6. bisco
    50,813
    agreed. or it may need a scan tool. try disconnecting the 12v for a minute.
  7. Rebound
    Rebound Senior Member
    3,970
    2,623
    Portland, OR
    Removing the 12V for a minute may reset the warning. However, the step you took may not have restored airflow. With that much gunk, I think you should take the cooling fan apart and clean it, because the fan itself may be clogged.
    There's a do it yourself video in this thread:
    Nutz About Bolts Prius Maintenance Videos | PriusChat
    #7 Rebound, Dec 26, 2016
    m.wynn, bisco and Prodigyplace like this.
  8. Tideland Prius
    16,403
    I didn't think the 3rd gen had a filter (the 4th Gen and Prime have air filters now)
  9. fuzzy1
    10,332
    A number of warning messages will self-clear after a handful or so of ignition power cycles, if the cause of the warning has disappeared. I do not know whether or not this is one of the auto-clearing messages.
  10. Data Daedalus
    Data Daedalus Senior Member
    1,025
    1,185
    Wembley, London
    It's a shame Toyota didn't come up with an aftermarket air filter for the 2nd Generation Prius - even if it was something to stop various types of hair getting through.
    iPhone ?
  11. Rebound
    3,970
    2,623
    Portland, OR
    The dash photo showed around 80,000 miles and it looked like a Gen III, although I've never seen such a filter either. I'd still clean out the fan if so much clogging occurred. That cabin got subjected to a lot of dirt or hair.
    WilDavis likes this.
  12. bisco
    50,813
    looks like dryer lint, portable laundromat?
    CNYhybrid and jeff652 like this.
  13. Mendel Leisk
    40,238
    I put in a piece of window screen similar to OP's pic. Every once in a while I shine a light through the outer grill, check it's condition. And every 2~3 years dig down to the fan, dust it off. You can clean the fan without complete removal. All in all, it's a bit of a hassle, but not that hard.
    After the first time pulling the hatch panel off the battery, I left the bulk of the fasteners off, just labelled and bagged them. They're very resistance to popping off, makes you you think you're going to break something. Makes it easier next time.
  14. avprius
    avprius Junior Member
    US
    Go to home depot
    Buy a furnace register filter
    A dozen for a couple of bucks
    Remove the outer grill
    Cut several filters to fit into grill
    Btw I hot glued 2 together and trimmed to replace cabin filter
    Anyone have any clever aka cheap alternatives?
    nssdiver, bisco and Data Daedalus like this.
  15. Mendel Leisk
    40,238
    Aluminum window screen:
    A couple of thread loops secure it.
    And digging down to the fan itself:
    This is all the disassembly you have to do, to clean it.
  16. liskipper
    liskipper Member
    373
    79
    Long Island, NY
    Have you tried pressing the "Disp" button on the steering wheel?
  17. saltdiscus
    saltdiscus Member
    198
    89
    US
    What did you use to clean your fan.I was right there with open fan but didn't know how to clean?
  18. Rebound
    3,970
    2,623
    Portland, OR
    You *could* fully remove the fan unit, disassemble it and then spray it with solvent until it's sparking clean, but... it's only purpose is to cool. It's not like a fan that blows fresh air for you to breathe.
    So if it's lightly coated with dirt? Do nothing. Or reach in with a Clorox wipe or Wet Wipe and clean as best as you can. But if there's a thick layer of hair or crud, you should disassemble and get all the hair-crud out and reassemble. You're only cleaning plastic; there are lots of ways to do it.
    DadofHedgehog and bisco like this.
  19. Mendel Leisk
    40,238
    Q-Tip.
  20. jeff652
    jeff652 Senior Member
    607
    624
    Idaho
    #20 jeff652, Dec 27, 2016
    ITBland and KennyGS like this.
