Nav/Map keeps reverting back
Discussion in 'Gen 3 Prius Main Forum' started by armoredsaint, Mar 5, 2013.
  1. armoredsaint
    armoredsaint Anti-Eco Company Car
    92
    28
    How do I keep it on the Audio display, or show both at the same time (Nav and Radio) like all other cars?
    Plus how do I re-center the map if I accidently press one of the areas on the screen?
  2. ZPriusv5
    ZPriusv5 Junior Member
    74
    Cincinnati, Ohio
    Haven't figured out a way to keep audio only on screen without reverting to the map but on my ATP Prius I can do the map & audio by pressing the "Map mode" button and then choosing map & audio mode
    To recenter the map if you move it around, press the physical "Map" button (same button you would push if you were on the audio or app screen and want to switch back to the map sooner than the normal timeout revert back to map)
    armoredsaint likes this.
  3. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,342
    Wilmington, NC
    On the 2010 Nav you go to Settings -> Nav -> Auto Screen Change and change from On to Off. The default setting is On which automatically switches the screen back to the Map. The Off setting keeps the display on the last setting.
    To re-center the screen I believe you just hit the Map button.
