Navigation disappointment
Discussion in 'Gen 2 Prius Main Forum' started by clifford, Mar 26, 2006.
  1. clifford
    clifford Member
    156
    I have a two day old 2006 and certainly enjoy it so far. Nav has been the downside. On a trip tonight it was way off in directions home and never corrected the route as I turned the most direct way. I have two Garmin units and they always get me back on route and say right away that I am off route, etc. This Nav said nothing, not a thing, until I was in my driveway and said that I was at my destination. I don't have confidence that this unit would direct me or redirect me.
  2. aaf709
    3,862
    2022 Prius Prime
    Too bad. :( On my 2005 there is an option in the setup to turn auto-correct on or off. I presumed there was an option in the 2006 as well.
  3. jbarnhart
    jbarnhart New Member
    629
    Santa Clara, CA
    Double check your nav settings and see if you have instructed it stay off freeways or something like that. I have found that the nav is pretty good unless I give it some weird menu settings.
  4. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    I think you need to spend some time in the setup screens. I don't have an '06, but with the 04-05 you had to program the system to redirect you if you took a different route...it's a customizable feature. As others stated, you can also customize to prefer or avoid interstates, and other routes.
    I suspect that once you get it set up properly you'll be more satisfied and confident. That said, it's clearly not a perfect system and it uses a lot of approximations for specific addresses and definately has some errors.
    I've been frustrated at trying to locate schools with the NAV.
  5. djasonw
    djasonw Active Member
    958
    119
    Coconut Creek, FL
    I own a 2004 and find the NAV to work exceptionally well. I also have a GARMIN Quest I use when I travel. I don't think I can live without NAVI.
  6. cowboy
    cowboy New Member
    85
    "Mountain Empire" region of southeastern
    I've not had that problem with my 06 Nav system. I haven't programed it and it automatically corrects me if I decide to go off course for whatever reason. I must admit to not spending time with the manual as the Doc recommends, but it's good advice.
  7. clifford
    clifford Member
    156
    Sounds like I should spend some more time on set up! I did not realize that I needed to direct it to redirect! It was a frustrating day with the Nav unit yesterday as it really did not get anything right. The routes(more than one) were way off and again I heard nothing from the unit until I was at my destination. Also when starting off it really does not start right away. So as was suggested I will look at all of my settings. Much less user friendly than the Garmin Street pilot or the Garmin ique m4! But I will give it more of a chance.
    Thanks for your reply.
  8. sotagear
    sotagear New Member
    46
    Santa Clara CA
    You probably need a bit of time to program that Nav correctly. However that's not to say it's the best nav around either. I did an experiment last year with my Magellan Roadmate 700 and a rented Prius' built-in nav. For the 3 trips I used both units and the Magellan was on the money every time and picked the best route (I know the area, so I know the best route anyway). The Prius nav did the same on one trip, but was not the brightest fish in the pond on the other 2 trips. Not that this is the test to beat all tests - ymmv.
  9. Andy Ling
    Andy Ling New Member
    28
    Haymarket, VA
    Hey Guys,
    I have an 05 with all options.
    The NAV system replaced my street maps(except for homes less than 2 years old).
    I have used the NAV system(4.2) that came with the car until last week. I got the 5.1 in the system now. The 5.1 is exactly the same as the 4.2 with up-dated information worth about 1 year newer than the last. It's good enough for my kind of needs here in metro Washington, DC.
    I will say this though. The NAV system is near perfect(99%). How do I know??
    I go to 10 to 16 different homes a week in Norther Virginia, DC and Maryland.
    I choose from the three route options offered by the NAV prior to start of the guided trip. I have a pretty good feel for the local route conditions on different periods of the day and choose accordingly. It saves time and is safer since I do not have to look up on the map while in motion. I have not used any other systems so I can not tell you which is better.
    Of the few disappointments, the majority ponted to the changes made to roads by the state or the county. Even the 5.1 is about 2 years old so I do not expect 100 percent accuracy. I am pretty comfortable with the PRIUS NAV system :)
    The 5.1 up-date cost me $260.00(after the in-store $15.00 discount) :blink:
    I would like to see a free inter-net based up-date program from the TOYOTA company. The initial cost of the NAV system, as compared to other after-market systems, is expensive to begin with.
    Andy
  10. aaf709
    3,862
    2022 Prius Prime
    Actually I didn't need to set it up. That was that way when I picked the car up. Whether that's the default setting or not I don't know. Someone at the dealership may have played with the controls and changed it. I know that when I had the 5,000-mile oil change done at a dealer someone had changed the temperature from 75 degrees to a rude, but amusing, 69 degrees.
  11. mssmith95
    mssmith95 Michael
    535
    Valencia, CA
    I have been using my 2006 NAV for the last month or so.
    It does auto-correct if I go off course, but sometimes the "suggested" route is really crazy. In downtown Los Angeles this weekend, it kept telling me to make several turns (like right, left, right) instead of just going straight and then making a final right. There is no possible way that it was giving me a shorter route, as this was in a small 3-4 block area.
    Bottom-line, common sense, and knowledge of a particular area beats the suggested route everytime. However, yours should auto-correct (note - the only time it does not auto-correct normally is if you select the "Detour" function...and I have found no way to cancel the detour route once it is selected!)
    So far the NAV has been a bonus, as it has helped me in areas I would otherwise not know.
  12. mitchbf
    mitchbf New Member
    105
    Chicago Area
    I just want to add that I'm directionally challenged but have found the NAV in my '05 to be darn good. The one interesting thing that I notice is that it will sometimes route me differently getting to a location vs. returning. I'm not sure exactly what's in the programming but I can say that it appears to "protect me" from having to make left hand turns on to four lane roads. It will take me around the block, more or less, in order to avoid this. Even though I don't always agree with its choice of routes, it always seems to get me there. I'm of the same opinion as the other posters that the settings in your unit may be off. One interesting thing that happened to me was that I tried to install a NAV Mod from Coastal (which didn't work btw). As part of the process the unit was powered down and when it came back up I had lost all settings. The most important setting, for me, was my geographical region. Took me a bit to realize what had happened and that's why the system couldn't find my town... :rolleyes:
  13. clifford
    clifford Member
    156
    I have the right region on my 2006 Nav. Also rechecked the setting today. Unfortuantely I did not see anything I could change. As with so many other windows on my display I am sure there is more to the display than I am finding.
    I can not see any settings that will let me direct the Nav to recalculate if I go off the recommended route. As I said before the recommended route was not even close to the quickest or the most direct. It was way out of the way. Yes the region is correct.
    I will continue to explore. Thanks for all of the input.
    Maybe someone could please lead me through this setting.
  14. aaf709
    3,862
    2022 Prius Prime
    I found it on page 81 of the 2005 Navigation manual. It may be somewhere near that page on the 2006. Basically, go to MENU and then SETUP. On the first page of that near the bottom is "Auto Reroute." That should be set to "On."
  15. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    I'm looking in my 06's nav manual and don't see anything like that (on p.65 that refers to the 3 pages of setup. The 3 options on setup page 3 are auto voice guidance, pop-up message and calibration). I've never even known of a way to prevent it from automatically rerouting if you miss a turn/go off course. It's always done it automatically for me.
    Perhaps the OP should check these settings:
    - doesn't have multiple destinations in a route in already
    - Areas to Avoid on p. 72
    - Route Preference on p. 42.
    - Voice recogniition guidance, Voice guidance in all modes, and auto voice guidance on p. 86-87
    The last 3 settings might have something to do w/hearing nothing until reaching the destination.
    For me, the nav system has generally been pretty accurate. I know there are some spots near my work that aren't right anymore, but the changes to the streets and highways in question happened well AFTER I got my my car, so it's impossible it'd know about them.
  16. Wildkow
    Wildkow New Member
    5,270
    37
    36
    OK now tell us which one you prefer! Personally I think the Garmin unit is superior but ymmv. For the life of me I can't get my NAV to route me down a particular street. Even when I'm on the street and it is the most direct route to my home the unit tries to route me up to 2 miles around just to avoid using that street. It's baffling and I have used at least 8 different/other systems but this is the first system I have used that is built in the others were portable GPS's or PDA based systems. The one notable feature you get with the built in sysems is that it is tied into the car itself. So that when you lose signal or go into tunnels or onto the lower lebel of a Bridge it estimates your speed and direction and displays its best guesstimate onto the MFD until its get the signal back.
    Wildkow
  17. NuShrike
    NuShrike Active Member
    1,378
    This is how I cancel the detour route: I don't follow the route it tells me to. My 2005 then reroutes and ignores that I was on Detour.
  18. clifford
    clifford Member
    156
    <div class='quotetop'>QUOTE(NuShrike @ Mar 28 2006, 08:22 AM) [snapback]231313[/snapback]</div>
    What I am hearing is that on the 2005 you are redirected and you can adjust settings to redirect. For the life of me I can't figure out why anyone would not want this feature set. Especially with some of the strange routing.
    But I am also hearing that on the 2006 they are not finding that setting and I did not find it either.
    If anyone with an 06 can enlighten me on these settings it would be great.
  19. ched1968
    ched1968 New Member
    <div class='quotetop'>QUOTE(Andy Ling @ Mar 27 2006, 09:48 AM) [snapback]230795[/snapback]</div>
    I have an 05 pkg#6 and my NAV has a 4.2 version. im just curious when you upgraded to 5.1 did the screen resolution changes just like one in 06 which is sharper/crisp? i'm considering to upgrade too. thanks
  20. paco-shalom
    paco-shalom Veteran Prius Owner
    62
    Phoenix
    I love the NAV on my 05 Pkg 6. It is more reliable and more up-to-date than the maps on the TomTom Navigator 5 software I bought for my wife's Palm.
    A couple of points:
    1. Another big advantage of the built-in NAV is that it is connected to the Bluetooth system, so you can call POI numbers with a couple touches to the screen.
    2. I've found that the routing will avoid roads that have different rules at different times of day (such as commuter routes which are one-way in different directions during rush hours) - I noticed this with Canal Road NW in Washington, DC. Even when you get on those roads, the rerouting tells you to turn at every opportunity.
    The updates to the NAV software cannot improve the resolution of the MFD, as that is limited by the hardware. There are different versions of the DVD for the 06 model and the earlier model years. When you upgrade, make sure you get the one that is compatible with your car. The only improvements you will find are that the maps are more up-to-date and the newer maps *may* cover more area in detail than a previous version.
