My system does not recognize daylight savings on arrival time now 1 hour later ?? how come can't figure out how to set it up after daylight savings I'm starting to see limitations and lame ways compared to my garmin zumo factory nav is low tech in a fine Hi tech car also radio is just so so love the car tho!!!
Artie, Daylight Savings Time is contingent upon locale. If you press the SETUP hard key to the right of the display. Then, press the NAVI softkey. This will allow you to turn Daylight Savings time on or off. Be sure and save your choice before exiting! As for Garmin -- my 2720 has to be told (a) what time zone it's in and (b) whether Daylight Savings Time is in effect or not, so the limitations aren't just to Prius. Keep in mind (as discussed in other threads), navigation receives GMT (Greenwich Meridian Time) from the satellites. It's up to the end user to specify within the SatNav device the appropriate offset for time zone and whether DST is in effect.
