Navigation System Computer failure ?
Discussion in 'Gen 2 Prius Main Forum' started by Hart, Aug 24, 2007.
  1. Hart
    Hart New Member
    I just took my '04 Prius in for the 75,000 mi. check and let them knoe the computer for the screen has been acting up. About 50% of the time it doesn't show info.
    Was told I need a new computer ! Yikes ! $4218 for the parts and $90 for labor. No extended warranty :(
    Has anyone else had trouble with this? I should be able to at least run the AC and radio from the steering wheel. Can I drive it without getting the new computer?
    Just put in a new compressor for the AC in May. This car is getting VERY expensive all of a sudden ! :(
  2. KTPhil
    KTPhil Active Member
    1,379
    22
    There were several threads about the display failing. I think they were replaced by Toyota, but this was on low mileage cars under warrantee. Try searching and see if you can find the threads. Try Prius Onlone, too, it might have been posted there, too. It is the display unit, not the computer, but it is still expensive. Maybe there is a used one off a wreck they can use?
  3. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    People here refer to the display as the MFD. I've seen a bunch of threads about getting refurb/remanufactured MFDs for a LOT less than $4K.
  4. qbee42
    qbee42 My other car is a boat
    18,058
    3,079
    Northern Michigan
    That year Prius had a history of MFD failures. You can buy a refurbished MFD for much less than a new one.
    Tom
  5. pettysteve
    pettysteve Junior Member
    Did they offer you a reconditioned DISPLAY UNIT?
    Do you have the part #, description and estimated cost?
    Thanks for any info -- a sister is having similar problems with her 2004 Prius
  6. shybrid
    shybrid New Member
    17
    <div class='quotetop'>QUOTE(pettysteve @ Nov 7 2007, 07:58 PM) [snapback]536549[/snapback]</div>
    When we bought our Prius we also got the extended warranty from Troy. If our MFD goes out will the extended warranty cover a new MFD? Or is that something that is excluded from coverage? Thanks very much
  7. flydeep
    flydeep New Member
    <div class='quotetop'>QUOTE(shybrid @ Nov 11 2007, 04:32 PM) [snapback]538045[/snapback]</div>
    I have the same question. I just got my Prius 08 with Pkg 6 delivered yesterday. I am thinking about getting the Toy extended warranty. Will this cover any problems with the MFD unit for 7yr/100k?
    thanks,
    deeps
