Need help with a DTC
Discussion in 'Gen 2 Prius Technical Discussion' started by cewert, Jul 8, 2007.
  1. cewert
    cewert New Member
    17
    I started my '04 Prius this morning and I noticed the check engine soon light came on. I have CAN-View installed (its a converted Plug-in hybrid), so I was able to retrieve 3 DTCs, and I'm wondering if someone with access to the official list can give me any clues as to what the problem might be. The DTCs are: (all under Engine DTC): P0111, C1100, P0000. From googling, P0111 seems to be something about an air intake temperature issue, but I can't find the other 2 (which may just be directly related?) The engine seems to be running fine, I can enter EV mode, stealth, etc. The only symptom I'm seeing is the check engine soon light is on. Any thoughts?
    Thanks!
    Chris
  2. TheForce
    3,461
    537
    Wheelersburg, Ohio
    C1100 ABS Pump Switch Circuit Failure.
    P0000 should be a general problem code.
