Need new struts/shocks, should I get coilovers? SoCal
Discussion in 'Prius v Accessories and Modifications' started by Dakota88, Jul 17, 2023.
  1. Dakota88
    Dakota88 Junior Member
    Los Angeles
    2015 Prius v wagon
    Proud new owner of a Prius V. Mechanic has suggested new struts and shocks. Considering if I should go for coilovers. I wouldn't mind maybe an inch lower than stock but want to maintain near stock ride comfort. Located in SoCal. Wondering if anyone who has done coilovers chime in on daily driving experience.
  2. Dakota88
    Los Angeles
    2015 Prius v wagon
    I will reply to myself haha. So far have narrowed down perhaps 2 options.
    1. Tein z flex Coilovers - Can lower it a bit w better handling and seems can maintain comfort
    2. OEM - Cheaper in the long run, reading Teins are built to last 50k-70k miles before needing to be re-built
    Decision? Don't know yet
  3. slow_wagon
    slow_wagon Junior Member
    30
    Upstate NY, USA
    How many miles are on your car? I'm at 215,000 on the originals and they all still work fine. No leaks. Maybe get a second opinion before replacing. If you definitely have to replace them, I would recommend OEM. The whole point of the Prius is low cost of ownership. You want struts that will last a long time.
  4. Dakota88
    Los Angeles
    2015 Prius v wagon
    Thanks for reply! 130k miles, mech says I have leak on one and worn on the rest. I do feel small bumps and hear them in cabin. Could be that LA has bad roads? Im sure tires will play a part as well.
  5. Dakota88
    Los Angeles
    2015 Prius v wagon
    Ok so I'm gonna chase the crickets away. Got some 18x8.5 Konig Hypergrams on 215/45r18 Michelin AS4s. I assume its not urgent to replace the suspension but probably will help the ride. Probably will go for Tein Flex Zs and probably adding the active EDFC to it. Will ride the stock suspension for a bit till I make a decision.
  6. Xterra72
    Xterra72 Senior Member
    1,425
    1,668
    Go with TRD Springs and OEM shocks.
    This was my favorite setup before I went with the Blitz Coilover kit. My coilover rides really rough especially when the car goes over potholes.
    I wish that I kept the TRD and OEM shocks combination. This setup rides smoother and going over potholes and was not that harsh of a ride compared to my Coilover kit.
    scona and JohnnyPR like this.
  7. JohnnyPR
    JohnnyPR Member
    96
    25
    Hinesville, GA
    A local mechanic also recommended that combination. One of their customer revert back to oem shocks when got nittos from 4Wheelonline. The aftermarket coilovers were not that comfortable says the owner.
    Xterra72 likes this.
  8. Dakota88
    Los Angeles
    2015 Prius v wagon
    Thanks for the info! I just saw this and had already placed an order that cant be cancelled for the Tein. So there is a bunch of contradicting info online regarding the subject. But I have come to the conclusion the Tein Flex are far more comfortable than other coilovers due to them being tuned for street and not for track. I was also recommended TRD springs with OEM shocks but I had also read lower springs on OEM suspension is really best for a low budget setup. I personally have done lowering springs on OEM shocks before on another car and it felt ok but performance over bumps/uneven surfaces was not good. Let's see how the Tein are with the Active electronic dampening system.
    Too bad there aren't more prius meet ups so I could get some real in person feedback haha
  9. Dakota88
    Los Angeles
    2015 Prius v wagon
    Oh also I don't plan on slamming my coilovers but to use them at max height, so I assume more travel with the shock will help the cause too...
