Need Technical help with battery and knee airbag
Discussion in 'Gen 3 Prius Technical Discussion' started by crash0099, Apr 15, 2011.
  1. crash0099
    crash0099 Junior Member
    28
    So. Georgia
    Hello Guys,
    I love this site. I recieved some good info on my last post and I do appreciate all the help. I have just taken possession of a 2011 Prius III (yeah). I was wondering if the JBL system is the same Head unit as in the II or is the Head unit and speakers JBL?
    My main issue is I now have to install the hand controls for me so I can drive. I, first off need to remove the Knee Airbag under the steering column so that I can put a 3K ohm resistor in place of where the airbag plugs in.
    1) Could someone explain to me what procedure I need to go through to accomplish this?
    Where are the clips on the panel so I don't break them? Where is the 12 Volt battery and how should I disconnect it so I don't mess anything up? How do I disconnect the airbag and where should I connect the 3K ohm resistor? Can I just bend a resistor and plug it in and it stay or do I need to solder the resistor to something to get it to work properly and stay plugged in?
    2) I normally bolt the hand controls to the bolts for the steering column in a regular vehicle. We all know the Prius is NO regular Vehicle. Can I access the bolts to the steering column or is there other items I have to move to get to them? Or does it have a different way that it connects?
    These are the main issues that I can think of now before I get started. This car may have other issues that I am not familiar with but someone who knows the car is. So that is why I could use a heads up on any thing before I start this job. I would like to have everything in place before I start to do this. I appreciate and thank you for any advice you may have for me. It is great having a site like this to refer to.
    Craig
  2. Teakwood
    Teakwood Member
    491
    73
    New Mexico
    I would strongly suggest that you work with the service dept at the dealership.
    Disabling airbags may have implications that are beyond the ken of many here.
  3. wesayso
    wesayso Member
    385
    35
    Hampton, VA
    S.K. reference? :rockon:
