Neutral in Car Wash
Discussion in 'Gen 2 Prius Main Forum' started by Marvinh, Dec 9, 2007.
  1. Marvinh
    Marvinh Marvin
    190
    NY - Long Island
    I went through an automated car wash yesterday. Came out fine. No scratches. However, I was wondering:
    The car was put in neutral at the start. If the engine had stalled in the middle of the car wash, would the CVT go into park, or would it stay in neutral?
    In other words If I put the car in neutral and then shut off power, will the CVT stay in neutral? For towing purposes, etc?
    Thanks! Marvin
  2. Marvinh
    Marvinh Marvin
    190
    NY - Long Island
    OK. I just answered my own question: If you are in neutral and power off, the CVT goes into park. I also realized that to keep the car in neutral with the power off, you have to be in IG-ON mode.
    However, that brings to mind another question: If the engine stalls (eg. while in a car wash), does the car remain in IG-ON mode, so that it may stay in neutral?
    Thanks. Marvin
  3. Bear68
    Bear68 Member
    373
    72
    West Palm Beach, FLA
    We had to figure out a simple solution for that in order to do alignments. On our Hunter laser type alignment machine, the vehicle must be rolled backwards and forwards during the course of measurements. Running the engine in neutral without someone behind the wheel is NOT my idea of safety. Here's what we do for Prius: Turn Power off, without stepping on the brake, press the power switch twice to activate "ignition on/engine off" mode, (just like having key on/engine off in a normal car) then step on the brake pedal and hold the shift lever to N. The Prius will be in neutral and can be rolled but the engine and HV drive systems will not activate. No worries of the car suddenly moving of it's volition.
  4. Dminor
    Dminor New Member
    Los Angeles
    why would you power off? I almost think of that as the equivalent taking the key out of the ignition.
  5. Marvinh
    Marvinh Marvin
    190
    NY - Long Island
    Dminor - I wouldn't power off. I was concerned if the engine stalled in the middle of the car wash. - Marvin
  6. alanh
    alanh Active Member
    1,175
    99
    Phoenix, AZ
    The Prius doesn't really "stall" -- after all, it's designed to shut off the gas engine while you're still moving. If the gas engine won't run, alarms will go off but the car won't go into park and you'll still have a limited amount of power from the electric motor.
    You can't normally shut off the Prius while it's moving. If you force it off (by holding down the power button), it will go into neutral. It will also go into neutral if you press the Park button while it's moving.
    It's possible the speed in the car wash is below the threshold for the Prius to consider itself "moving", but I wouldn't worry about it. You'd have to have multiple serious failures of the hybrid drive to get it go to into park unexpectedly.
  7. Marvinh
    Marvinh Marvin
    190
    NY - Long Island
    Thank you Alanh. Exactly what I wanted to hear! ;) Marvin
  8. JaviNOS
    JaviNOS Mod Freak
    150
    Puerto Rico
    Ok... that happened to me.. The car sucked all the power while on N.. I think I was halfway throght the car wash. It sounded the alarm and displayed the alert... but I just waited until the end and got on D.. and that's it... They cleaned it inside while it still was on so it charged itself.
  9. Bob64
    1,540
    93
    Virginia
    Best way to get through a car wash:
    Turn off everything. AC/Radio/Headlights. Then you can probably stay in neutral for at least an hour... I think
  10. patsparks
    10,664
    567
    Adelaide South Australia
    Or you can wash it by hand.
  11. hill
    8,562
    Hand? What's that?
  12. Sarge
    Sarge Senior Member
    1,321
    775
    Milton, Ontario, Canada
    2023 Prius Prime
    XSE Premium
    Hmm... that made me just think of something...
    Normally, when the car is powered off, it will automatically shift into Park no matter which "gear" you are in (R,N,D,B). However, if you are rolling and hold power to do the emergency shutdown, it remains in N. Therefore, the car is mechanically capable of doing this. I wonder if there exists a hidden way to do this while the car is not moving?
    Perhaps holding the power button to shut off? I've never tried it... Hmm...
  13. daniel
    14,487
    1,519
    Spokane, WA
    I am not certain, as I have not tried this, but if you press the Power or Park button while the car is moving, I do not believe it shuts itself off. It JUST shifts into Neutral. You can then recover by shifting it into Drive (if you are moving forward) or Reverse (if you are moving backwards).
    The inability to go into Neutral while off, for towing, is in my opinion a flaw in the design.
  14. KMO
    KMO Senior Member
    1,790
    580
    Finland
    2023 Prius Prime
    If you hold the power button down while moving, it goes into ACC mode, but in Neutral. You can only shift into Park from there (once it's stopped).
  15. fruzzetti
    fruzzetti Customization-Obsessed
    377
    California (Pulled over 6x, ticketed 2x for tint)
    This is how you should think of that. Also, if the hybrid system malfunctions (the only way the car is going to "stall out;" remember it's DESIGNED to turn itself off), it will remain in neutral or electric-only drive mode, which means it is STILL safe to take through that car wash (the block seems to be sealed against water or otherwise unable to accidentally crack -- this has to be something they thought of and engineered out safely).
    ~ dan ~
  16. abq sfr
    abq sfr New Member
    690
    Albuquerque, NM
    I just put the key in the "hidden" compartment and let the car wash people take care of it. You would think that Prii are common enough now that they would know how they work. Usually they put the emergency blinkers on, but I think they do that for cars that stall (engine not running) and are in neutral. Darn, my car stalls all the time! I usually lose a couple bars on the battery, but gain them back right away.
  17. daniel
    14,487
    1,519
    Spokane, WA
    A very risky assumption! Even if most of them do in your area, there's going to be that one kid who thinks he's smart enough to figure it out just by looking at it, and he's going to get out of the car while it's in Drive, and it's going to roll off and bump something.
  18. Marvinh
    Marvinh Marvin
    190
    NY - Long Island
    The car sounds an alarm when it sucks all the power? :eek: I didn't know that! Is the alarm loud enough to hear outside the car? So if a car wash heard an alarm would they shut down the line?
    Also, when it sounded the alarm did it stay in N or did you switch it to D manually?
    Marvin
  19. Bob64
    1,540
    93
    Virginia
    I believe you can get it to shift into neutral if you go into the non-ready mode (push the power button 2 times without pushing the brake). Then remove the parking paw fuse (or something), apply the parking break, then proceed to turn the car off.
    Read somewhere on hobbit's prius tech training manual.
  20. Kidd
    Kidd New Member
    75
    Port Orange, FL
    Car wash sounds like it could be trouble.
    I think I will just wash mine by hand too!
