New Car Air Freshner on Back Seat Battery Vent
Discussion in 'Gen 3 Prius Accessories and Modifications' started by MarcusRepublic, Jul 12, 2012.
  1. MarcusRepublic
    MarcusRepublic Junior Member
    I have a 2012 Prius and I absolutely love it! I have had it for two months & it has just lost the brand new car smell. I went to Walmart and purchased a new car smell air freshner that attaches to the air conditioning vent. I was thinking that I might attach it on the air vent that vents heat from the battery in the backseat. Does anyone see a potential problem that I might run into if I do this? I would much rather not put it on one of the air conditioning vents in the front if the car because I would like to keep that "clean" dashboard look in my car.
  2. Paradox
    29,110
    8,591
    201
    2014 Prius v wagon
    That vent sucks air in, so it'll suck the new car scent into it rather than blow it out into the car.
    Also, why block/restrict the flow of air into the vent which is needed to cool the battery with anything. Just my opinion.
    GrumpyCabbie likes this.
  3. MarcusRepublic
    Thank God! I seriously thought that the vent in the back seat was venting hot air into the car. I have determined that I will clip the air fresher on one of the front vents when I leave the car parked in the sun to let the solar power fan spin and freshen up my car.
  4. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    No, the flow is over the battery and then out through two exits at the rear of the car. Doesn't recirculate.
  5. PHEV-1
    PHEV-1 Junior Member
    Kalamazoo MI
    Do you happen to know where the two vent exits are located at the rear of the car?
  6. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Either side of the rear of the car (behind the rear bumper skin. You can see the right side if you are working on the 12v battery.
  7. RRxing
    RRxing Senior Member
    2,528
    1,803
    NEPA
    They are just simple, louvered vents. The rear bumper covers them up. They look like this:
  8. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Why not just stick it under the seat out of view? Or does it need air flow to release the smell?
  9. bisco
    50,813
    what if you laid it on top of the cabin air filter?
  10. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    That would all depend on how thick it is. There's not much room where the cabin air filter is.
  11. phoenixgreg
    phoenixgreg Senior member
    1,157
    291
    66
    Phoenix
    That actually works fine as I do that all the time. But I place it under the filter resting on 2 plastic ribs so it won't get sucked into the fan. This is of course is one of those "Little Trees" which is flat. Also, if you try this trick, be sure to cut off the string first. The 2 plastic ribs are closer to the passenger door or the right side of the filter compartment. The problem is you need to do this monthly which entails removing the lower glove box.
