NEW high pitch whine (louder outside car)
Discussion in 'Gen 3 Prius Main Forum' started by 134HP Bard Womyn Magnet, Jun 12, 2023.
  1. 134HP Bard Womyn Magnet
    103
    28
    NYC
    Hi there. Brand-new sound yesterday driving on the highway. It was sporadic and mostly not happening, but it was a very high-frequency whine, non-changing pitch. Didn't really sound like inverter/"CRT" high whine, it was a bit more substantial, meaning maybe lower frequency that that almost supersonic sound. It sounded like it was coming from the rear of the car.
    I opened the windows and it was louder, so it didn't seem like it was originating in the interior of the car. I couldn't quite map it to any particular "states" (meaning IC engine or coasting or EV modes) because I was going about 65 up and down hills and it seemed to just start and stop at random.
    One thing I will note is I got my oil changed and you can see the schmucks who did it didn't button up the plastic shield/door properly underneath. It's like 2-3" off the ground and messy, so I wondered if it was wind going through it, but it really sounded electronic or like a mechanical squeal. Any ideas?
    #1 134HP Bard Womyn Magnet, Jun 12, 2023
  2. ColoradoBoo
    ColoradoBoo Senior Member
    1,110
    728
    Monument, Colorado USA
    So you only hear it at speed? What speeds? Louder/quieter when turning? Could be anything, actually....wheel bearing going out to brakes to transmission..... Need more info!
    Yep, you got a hack mechanic with that oil change...."trust but verify" is my motto when anybody touches my car....I'll even check the oil levels immediately after getting it back. (Lots of horror stories available.)
  3. Montgomery
    Montgomery Senior Member
    2,254
    2,241
    Orange County, CA
    If one doesn't button up underneath after oil change, yes, it will flop on the ground and make a noise..............as it scrapes the ground.
  4. 134HP Bard Womyn Magnet
    103
    28
    NYC
    Afraid I don't have any besides that I was doing highway speeds and going more or less straight. Didn't sounds or feel like a wheel bearing and I didn't hear it at all tooling around at low or highway speeds today. However when I started the car today it kinda did an initial rumble which made me shudder a bit. I hope it's not related, but perhaps I turned it off before it went into EV mode (I've had this happen occasionally when turning it off during a warm-up cycle). OR my HG is going...
    I don't like to comment on physical appearances...but after my sanctimonious comment there, I'll be a total hypocrite and say this dude looked like he was out of central casting for an ingrate. He got out, grinned and said "I couldn't reset the maintenance light!" and threw me the keys. Haha! Maybe that was a tell. I pulled over in the lot, checked the oil level and reset the light. Stupid me forgot to look under the car, though.
  5. Montgomery
    2,254
    2,241
    Orange County, CA
    Most of us have had this type of "mechanic" before. Its what prompted me to do as much as I can myself. Back in the day, you couldn't just "google" something to find out how to do it so it was a longer learning curve. Today, you can find a youtube "how to do it" on just about anything. Sometimes, I look for how to videos so that when I can't fix something, I still know if the person I hired seems to be doing it correctly.
    ColoradoBoo likes this.
  6. bisco
    50,815
    certainly worth checking the wheel bearings even if it doesn't sound like it, and the cv boots.
    can you post a recording?
  7. 134HP Bard Womyn Magnet
    103
    28
    NYC
    It hasn't done it since but if I can get it regularly again I will.
    I'm now getting rough starts...the worrying noises tend to come in clumps.
    Cylinder misfires. Maybe I'll no longer be a Prius owner soon.
  8. bisco
    50,815
    any trouble lights?
  9. 134HP Bard Womyn Magnet
    103
    28
    NYC
    None yet - get the occasional P0A80 because battery is original. I reset it with my phone and keep going. :p
    The rough start definitely is freaking me out. Coinciding with the loose plastic splash guard, I first hoped it was that vibrating, but it doesn't seem to be the case. Plus that would keep vibrating. This just does it for 10 seconds max on startup then smoothes out for the rest of the trip, which seems like a HG thing.
  10. bisco
    50,815
    Possible, but hopefully an egr circuit problem
  11. 134HP Bard Womyn Magnet
    103
    28
    NYC
    Engine light on start today (ironically, it barely shuddered this time).
    F##k.
    Will passing (reasonable percentage) a leakdown test point to an EGR problem?
  12. ChapmanF
    16,960
    EGR is normally not active at engine start. EGR is used at mid-loads, not at wide throttle and not at idle.
  13. bisco
    50,815
    i suspect so, when i say egr, i include clogged intake manifold ports
