New Inverter Pump: Am I Supposed To Hear Coolant Flow?
Discussion in 'Generation 1 Prius Discussion' started by DBD, Apr 22, 2025.
  1. DBD
    DBD New Member
    Carbondale, Illinois
    2002 Prius
    Recently replaced the inverter pump after realizing it wasn't working and getting a check engine light (P3130).
    Zero coolant loss and I used a tight pair of pinch off tools so I didn't lose coolant and introduce air in the system.
    Starting out cold, it was very quiet and could only be seen as working by the turbulence. After a spirited drive, I noticed that I could hear the coolant movement with the cap on with lots of turbulence
    I have attached a video to demonstrate the sound after a spirited drive.
    So far the inverter isn't overheating. Is this normal for a G1 or do once warmed up I need to attempt to bleed the inverter coolant system?
