New Mobil 1 Sythetic Oils?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by V8Cobrakid, Feb 28, 2005.
  1. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    http://www.mobil1.com/USA-English/MotorOil...erformance.aspx
    Here is a link to the 15,000k mile interval oil. It's guaranteed to last 15k miles between oil changes. For us prius owners, this could possibly give us 20k miles? Maybe even more. I, for one, would really like this product. I have yet to look at the price though.
    I currently use Mobil1 Sythetic blend and like it. I have over 20k miles on my car (almost 25k) and have been using sythetic for a while.
    There is also a 5k blend and 7.5k blend.
    here's a link for the 5w-30 blend
    http://www.mobil1.com/USA-English/MotorOil...ance_5W-30.aspx
    I'm noting that they mentioned this: "Please follow the recommendations in your owner's manual while your car is under warranty." in the discription in the end. They say "A special oil filter is not required."
    Now.. that prius post about a magnet in the drain plug comes to mind with waiting this long for oil changes.
    What's everyone elses thoughts?
  2. V8Cobrakid
    3,790
    152
    Another Interesting piece from the webpage: Note: 15,000 is not on this list. Warranty issue? Under Warranty is one of the questions to get to this page.
    What's the right oil for my car?
    Our products in the viscosity right for your vehicle
    We've taken what you told us about your vehicle and driving conditions, and using an auto industry database, have determined our products in the viscosity recommended by your vehicle manufacturer. To learn more about a product, click its name.
    Current Vehicle:
    Year: 2004
    Make: Toyota
    Model: Prius
    Engine Type: 4 cyl. 1.5 Liter
    View printable
    Mobil 1 5W-30
    A fully synthetic motor oil, Mobil 1 5W-30 with SuperSyn Technology, is the approved and the first choice of many premium car manufacturers, including Corvette.
    Mobil Clean 7500 5W-30
    Mobil Clean 7500 5W-30 is a synthetic blend motor oil designed to exceed engine warranty requirements. It delivers guaranteed performance and protection for up to 7,500 miles or 6 months, whichever comes first. Mobil Clean 7500 has 18 percent more cleaning agents than Mobil Clean 5000 to keep your engine cleaner longer.
    Mobil Clean High Mileage 5W-30
    Mobil Clean High Mileage 5W-30, a conventional motor oil, is designed for vehicles with more than 75,000 miles. It delivers proven protection of critical engine parts from lubricant-related failure for 5,000 miles or six months, whichever comes first. Mobil Clean High Mileage includes seal conditioner to help prevent leaks in high mileage engines.
    Mobil Clean 5000 5W-30
    Mobil Clean 5000 5W-30 is a conventional motor oil that delivers proven protection of critical engine parts from lubricant-related failure for 5,000 miles or six months, whichever comes first. It is designed to exceed most engine warranty requirements.
  3. V8Cobrakid
    3,790
    152
    If you de-select "under warranty" then 15,000 mile blend comes up as an option.
  4. V8Cobrakid
    3,790
    152
    hmm.. check this out. On test it out performs Mobil1 by a landslide. oil changes up to 25k miles or 1 years. meets or exceeds warranty requirements. Some people have reported running hundreds of thousand of miles with this companies oils. 400k miles on a diesel. many others too.
    https://www.amsoil.com/storefront/asl.aspx
  5. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    Interesting, I've seen the commercials and wondered what they would do/say about warranty issues. I guess they're not quite ready to sell the farm and claim you can go 15k while under warranty. I'll stick to Mobile 1 during my ICE warranty period at least.
  6. Ray Moore
    Ray Moore Active Member
    857
    52
    Texas Hill Country
  7. mspencer
    mspencer New Member
    101
    Council Bluffs, Iowa
    According to those descriptions, though, only the Mobil 1 in that list is actually fully synthetic. The others seem to be a blend of synthetic and conventional, or fully conventional.
  8. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    While under warranty, you had better follow what Toyota recommends. Here in Canada, oil and filter change every 8,000km or 6 months.
    If you happen to use an oil that claims a certain time or mileage period, and something DOES go wrong, you then get into a p****** contest with Toyota and whomever made your oil. Good luck!
    That said, it appears the Mobil 1 EP line of oils are not Energy Saving listed. They are designed for more severe service, they also offer a 10W-40 and a 15W-50, a viscosity usually used in high performance applications.
    I intend to use Mobil 1 0W-30 while on warranty. If I still have my Prius off warranty, Mobil 1 0W-40.
  9. tochatihu
    tochatihu Senior Member
    9,457
    3,656
    Kunming Yunnan China
    2001 Prius
    Prius here is 2001 model year and I have been performing the oil and filter changes since the freebies ended at 37k miles or so. Now with 70k miles the longest I have left Mobil 1 synthetic in has been about 13k. This oil was analyzed at 7 and 13k (with an intermediate filter change at 7k) and was very good in terms of wear metals, silicon (dust), soot (ring blowby) and viscosity. I replaced the oil after 13k because the "total base number" (TBN) had fallen to a low level.
    My intial indications are that this synthetic oil may be relied upon for 13k. Without knowing more about the filter, I would not talk about skipping the intermediate filter change.
    I have put these oil analyses on yahoo before and am happy to post them here if needed. Please understand I am not able to assume liability for what you all do with your cars, but I will share my results. You make your own decisions.
  10. DanMan32
    DanMan32 Senior Member
    3,799
    27
    Tampa Bay, FL
    To answer the poll:
    Not unless you can tell me how the oil magically eliminates combustion contamination.
  11. V8Cobrakid
    3,790
    152
    lol Dan. My third answer was " need to learn more" type of answer.. it didn't work on the poll though *shrug*
  12. V8Cobrakid
    3,790
    152
    The reason i bring up this post is for opinions. I trust the opinions of people on PC. In my case, i drive 5k miles every month. An oil that would last 3 months 15k miles would be very nice for me. 10k would be cool too. Anything over 5k miles would make my life just that much easier. I don't always hit 5k miles every oil change. Sometimes more. The most has been 7500miles or so. I always use Mobil1. *shrug*
    Maybe i should just stick with my current oil changes.
  13. jayman
    13,439
    641
    Winnipeg Manitoba
    Dan:
    A motor oil does *not* "magically" eliminate the byproducts of combustion. What a motor oil *does* is - through a carefully selected basestock and additive treatment package - *cope* with the byproducts of combustion.
    A major stumbling block to extended oil changes in North America is - ironically enough - the oil industry itself. For a long time the API (American Petroleum Institute) made up the oil specifications. Since the API is in the business to promote the petroleum industry, and with the protection of the Magnuson Moss Warranty Act, it has always promoted short oil change intervals.
    A lot of that has to do with how crappy the API motor oil specs are compared to the ACEA specs. For example, up until recently, a motor oil that met the API approval could thicken 500% in service. A motor oil that thickens that much needs a hammer and chisel to get it out of the pan.
    API specs also allowed 40% of a motor oil to vaporize in testing, so not surprisingly the test engineer was allowed to add up to 8 quarts of makeup oil during the relatively short 80 hour engine stand test. FYI current SL specs are somewhat stricter in that only 25% of the oil can burn off, and it can "only" thicken by 250%.
    The ACEA usually sets the limit at 15% vaporization and 80% thickening. No makeup oil is allowed during the 200 hour test. This is quite a difference to motor oil life.
    In Europe, the car maker is given almost free reign to set the motor oil specs. I bet you wondered why VW and Mercedes had such odd specs? That's why. The testing authority is the ACEA :
    http://www.acea.be
    If you examine the ACEA A3 and A5 specs, especially the B4-02 spec, there is a huge difference in how test engineers specify the performance of the motor oil.
    The primary motor oil contaminate is moisture from condensation and blowby. This tends to create acid in a gasoline powered motor oil. To combat the acid, an oil must have a high TBN (Total Base Number).
    Mineral oils usually cannot be refined with high TBN levels as the basestock and additives cannot handle it. The exception is certain HD diesel motor oils, such as 15W-40 viscosity to meet CI+ specs.
    Regular cheap North American motor oils might have a TBN of 4-6. A very high quality synthetic A3/B4-02 motor oil might have a TBN of 12-15.
    So a high quality synthetic motor oil not only holds up better due to the better basestock, but the additive package is more able to cope with combustion byproducts.
    At a certain level, the oil filter has to plug, and that usually sets the oil change interval. Unless you're willing to invest in bypass oil filters, which theoretically allow oil change intervals of +40,000 miles.
    Since Toyota appears to mandate at least a semi-synthetic 10W-40 oil in most of Europe, they also allow a 1 year or 16,000km oil change. We don't seem to be hearing of many Prius motors blowing up in Europe.
    Before the PriusChat site crashed, I posted some URL's of VW in the UK and their long-life service regime of up to 2 years or 50,000km if they use a special Castrol LongLife SLX 0W-30 motor oil. Did you follow that URL??
    So it's not "magic" but carefully-controlled chemistry. That said, if I had to run some cheap generic crap 5W-30 North American oil, I'd probably change it every 3 months or 5,000km. That stuff is garbage.
  14. V8Cobrakid
    3,790
    152
    well said Jayman
    Now.. i change my oil myself. If i have problems, they are most likely going to point the finger at me anyways. I have no way of properly documenting that i changed my oil, unless i show them my oil and filter receipts.. ok.. n/m.. but still. If anything goes wrong, it's a fight between the oil makers, myself, and Toyota. I'll probably be the one to lose.
    So... think the better sythetic is a bad idea? I think i mented that i travel approximatly 6,000miles a month. That's while using my synthetic. You could use normal crappy oil and travel 5,000 miles. When i change my oil, it is still oil. Usualy it gets more a a gasoline type smell because it starts breaking down. I wish i could properly test my oil. i would like to know how far the oil will go
  15. jayman
    13,439
    641
    Winnipeg Manitoba
    <div class='quotetop'>QUOTE(V8Cobrakid\";p=\"68511)</div>
    As you stated, since you do your own oil changes, you would get into a p******* contest with Toyota if anything *did* go wrong with the ICE. So it probably wouldn't matter if you used the Mobil 1 EP and extended the OCI. Make sure to use the "tall" Toyota filter, it has greater filter capacity.
    With careful documentation, the Mobil 1 EP line of oils may work well for you. I haven't read the fine print for their "warranty" is it quite picky?? Eg: does not apply to new cars under factory warranty or some such nonsense??
    Have you looked at other Mobil 1 oils specifically formulated for extended oil changes, with approval to European extended drains? For example, Mobil 1 0W-40 meets the Long Life specs of BMW, Porsche, MB and others:
    http://www.mobil1.com/USA-English/MotorOil...il_1_0W-40.aspx
    The real problem here is whether or not you fall under the car maker definition of "severe" service, which usually requires a 3mo/3,000mi OCI.
    And the irony here is that if you go to a dealer and have them maintain your Prius with their cheap generic 5W-30, you will have the full protection of the Powertrain warranty. However, once that Powertrain warranty is up, and you still have your Prius, what happens if your ICE is a sludged-up mess? Oops! TFB you're SOL.
    What I intend to do is to use Mobil 1 0W-30 but to run it to the maximum interval I'm allowed while maintaining Powertrain warranty. If I still have the car off warranty, once a year or every 16,000km like in Europe.
    You can have UOA (Used Oil Analysis) performed on the oil you drain. I'm sure there must be labs in your area that perform this test? You're in a very major urban area. The UOA will tell you about things like glycol contamination (Coolant leaks), excessive moisture, fuel dilution (Leaky injector or other fuel problem), and TBN level (How much life the oil has in it).
    Once you do several UOA's, the testing lab will make recommendations on when to change the oil. You'd be surprised at the results, some folks operating under "ideal" highway and climatic conditions can dramatically extend their OCI.
  16. V8Cobrakid
    3,790
    152
    Thanks for the info. I'll give it a try. Change it at 10k maybe or possibly sooner. Get it tested and see what they say. If i can run longer, i'll run longer.
    As for the oil filter. You mented to used the "tall" one. I don't use toyota filters or oil. I purchased the K&N filter. It's kinda small... hmm.
  17. bozebuurman
    bozebuurman New Member
    The Netherlands
    I live in Holland and I'm now driving a French car (Renault). It is custom for this car to change oil every 30.000 km (= aprox. 18.500 miles).
    btw I just bought a Prius
    Greetz from Holland
  18. Charles Suitt
    Charles Suitt Senior Member
    1,637
    17
    Dallas TX
    :rolleyes: Actually, I use Mobil-1 5W30 BUT I would *NOT* go 15K miles between oil changes. The cost of an oil/filter change is too low to risk engine problems.
  19. aileronguy
    aileronguy New Member
    I have a FOrd Escape and Focus that have been running Amsoil for years. Thye have survived wonderfully, and I bet this is Mobil's answer to the technology already present in the oil industry.
    The Escape even ran 15 miles w/o any oil in it at all...the 2 mechs I took it to couldn't find anything wrong with it!!
  20. aileronguy
    what about the oil filter? how often does IT have to be changed??
