New Owner 2005 185K Miles, neglected for a year
Discussion in 'Gen 2 Prius Main Forum' started by leaded, Sep 9, 2022.
  1. leaded
    leaded Junior Member
    Central FL
    Hi all,
    Just wanted to check in and say hey to you other Prius owners and share the journey of bringing my poor neglected ride back to its former glory. TLDR - doing stuff, give me tips on more stuff to do to my 05.
    I picked up a 2005 Prius off FB marketplace for cheap from a guy that only had it for a year but here are the problems I've dealt with. I'm looking to compile a comprehensive list of remaining maintenance items or typical problems to check if anyone has any input I would appreciate it.
    1) The previous owner had a tire blowout front left, which ripped up the wiring harness. PXL_20220824_231723295.jpg
    The first stop, the junkyard, got the section of the harness I needed including the two connectors for the coolant heater reservoir area and wheel speed sensor for 10 bucks, score!
    Hook spliced in with leaded solder, heat shrink, and electrical taped for good measure. Dealing with the ripped-up fog light wiring later...
    The guy I got it from took it to Walmart for tires after the blowout, looks like they broke one of the rusty wheel hub bolts off, he was riding around with 4 lugs for about 1000 miles...
    Replacing the wheel hub was a tough job, I tried using a slide hammer but ended up having to pull the knuckle off the car and beating the ever living crap out of the old bearing to get it out. Probably could have used a torch or press if I had one, but a recent move has my tool collection at its leanest in a while.
    Didn't get any pictures of the finished job because frankly I was exhausted after this one.
    When I bought it, the guy said it needed brakes, what do you all think?
    After putting the knuckle back in I did note the boots on the sway bar links and tie rod end were ripped and sad, so I ordered up some replacement stuff from RockAuto. Nothing special, just doing Moog Inner/Outer tie rods, ball joints, and sway bar links for now. While I was on there I ordered up some new rotors, the old ones are rusty and well etched from the neglected brakes. The serpentine belt also looked overdue so I grabbed that, and a new tensioner pulley because why not?
    While I was cleaning out the car I found the only maintenance receipt, which was for the HV battery replaced at 133K miles 5 years ago at a Toyota dealership in Georgia. Score!
    I failed to mention it, but when I first checked the oil, it was slightly overfilled, so the first thing I did was change the oil again, 3.5 qts. They had been driving on the 3.9 the Walmart service center put in for about 1k miles, hope the motor doesn't hate me...
    I also intend to change the transmission fluid, I have 4 qts of Toyota WS ATF sitting in the garage for the weekend.
    Picked up the OEM silver key from Toyota over the Labor Day weekend at discount and using a site found here I got a seed reset code for Techstream and managed to recover SKS functionality, the only key I got with the car was a second-hand used black key cut for a different car. (I have a few spare codes if anyone needs one.)
    After clearing the fault codes, the remaining code is for a p0420, I checked out the cat and it's clamped in, and also looks to be a pretty old aftermarket unit. Any suggestions on a decent replacement? I don't need to pass any smog tests in Florida.
    You might be able to tell I'm a bit obsessed with this thing!
    Cheers,
    Andy
    Prius Rising and bisco like this.
  2. Tombukt2
    Tombukt2 Senior Member
    11,555
    2,029
    Durham NC
    P0420 code here in NC 2 plus years . No part so far has cleared it it'll make it go away for a day or two and then right back O2 sensors different cats nothing seems to make any difference it's not burning any oil runs pretty clean and lean so I've stopped searching for the problem I don't have to pass emissions either and it's clean so when I say clean I mean exhaust gas temperature sensor clean for the year and model specs so I don't know whether the computer's bad for the exhaust part of it or what but it's something that I don't worry with if I ever have the dash out again I'll just remove that lamp because I check it so often with a scanner and whatnot like once a week or something no need for a check engine light basically
  3. highmilesgarage
    highmilesgarage Active Member
    408
    145
    Kansas City
    if the cats are not clogged you can just buy an 02 spacer in Ebay to get rid of that P0420. This will not work for areas where they visually inspect and check the 02 sensors for emission.
    ColoradoCrow, Prius Rising and leaded like this.
    50,804
    congrats and welcome!
    sounds like you found a unicorn, all the best!(y)
    Prius Rising likes this.
  5. leaded
    Central FL
    I'll try this out, thanks!
  6. leaded
    Central FL
    Thanks! Time will tell but I sure hope so!
  7. leaded
    Central FL
    I'll try a couple of the basics but yeah I'll probably just ignore it if it's none of the usual stuff. Probably better off mounting my Techstream setup below the information display :D
  8. SFO
    SFO Senior Member
    5,302
    4,244
    Northern California
    Welcome to PriusChat!!
    Check and clean up the HV battery fan. Peel the sticker on the back and give it a couple of drops of machine oil or 3-1.
    Do you have standing water anywhere in the rear? (spare tire area, 12v cubby, etc.)
    FYI : you're moderated until you've posted 5 times.
  9. leaded
    Central FL
    I didn't see any water when I checked, I pulled the blower and cleaned the fan blades with some qtips and alcohol, but I didn't think to lubricate it, so back off comes the trim! (I did blow out all the ducting with some compressed air as well, not sure if that'll do anything but why not...)
  10. leaded
    Central FL
    I saw a tip on these forums to register the car in the Toyota owners portal, more good news, the ABS actuator was replaced in 2020... Still, I do notice when I let off the brake it doesn't build back to full pressure immediately (more like 50%.) I will probably start by checking the drums, the parking brake doesn't seem to do much at the moment either, it works but barely.
  11. leaded
    Central FL
    Adding an o2 spacer did work to clear my P0420 DTC, I've run it about 400 miles since without the code returning. Thanks for the tip
